Question about Dishwashers
Pump keeps running & willnot let water in - Dishwashers
    President:
  • 1,462 Answers
I assume you mean drain pump.
machine probably has water in base. if you can, take bottom kick plate off and mop out the water - disconnect from mains when you do this. alternatively, tilt machine back at 45deg and water will run out.
if fault reoccurs, then you have a leak
Posted on Jul 14, 2008
Keeps running but no water getting collected
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 13, 2011 | DeLonghi Dehumidifiers
Cycles off & on the fan runs, but it doesn't draw any water in to the pan
heatman101
Aug 09, 2011 | Whirlpool Dehumidifiers
My Dehumidifier goes on for 3 minutes & shuts off. Cleaned filter, adjusted humidity settings, & moved unit to different areas of basement.
heatman101
Aug 05, 2011 | Dehumidifiers
It keeps running, but no condensation. Model AD50USS2
heatman101
Jul 10, 2011 | Whirlpool AD50USS Dehumidifier
Will not run. low & high speed light on even on. no water in bucket
heatman101
May 14, 2011 | Haier Dehumidifiers
My humidifier runs, but no water is collected. It will start and just keep running. Could something be clogged. The filter has been cleaned. It has sat not running through the winter.
heatman101
Apr 21, 2011 | Haier Dehumidifiers
It runs but no water comes out and the humitity level in the basement keeps going up?
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 16, 2010 | Fedders Dehumidifiers
My pump just humms willnot pump water
Im talking about general troubleshooting here. Usually with this size of motor 1Hp. Check if it have a capacitor, commonly if this humms the capacitor is faulty. It is a capacitor start motor. Another fault could be stuck up. Or one of the winding has a short. Hope it helps
Jun 04, 2009 | Sta Rite Dyna Glas Pump 1 Hp Ne857
New water ace sump pump will run but willnot shut off
The higher you pump the water, the stronger your pump needs to be, or the skinnier your hose needs to be. A lower discharge point and / or a smaller diameter hose might help immensely.
Mar 01, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I have new Bosch dishwasher..lassic electronic....the check water level keeps coming on because water is not pumping out....tried to reset and it still willnot pump out....any suggestions
check the drain connection.....if it is connected to a garbage disposal make sure the drain plug knock out is removed otherwise the dw will not drain. Also make sure the drain hose is not pinched or kinked.
Aug 02, 2008 | Dishwashers
Dishwashers Logo
152 people viewed this question
Top Dishwashers Experts
