Question about Printronix T5000r Label Printer
Printronix T5000r Label Syntax to print " character
We need to print labels containing the 'inch' character: "
Our printer instruction code is causing an error when printing, as the " character is being interpreted as the end of the line. An example of the print instruction is below, where we would like this to print: text " text.
What is the Syntax we need to use in this case, please?
D;POINT;075;095;12;6;"text " text"
Thanks for your help.
Roscoe
  • Printronix Master
  • 2,794 Answers
It is a syntax error.
It should read:
D;POINT;075;095;12;6;"text"
You might be able to get away with this:
D;POINT;075;095;12;6;"test";"text"
quotes have to be in sets of two and elements have to be seperated by semicolons.
Posted on Jul 14, 2008
Will not print
need more info please contact me back rcardenas@themrpsolution.com
Apr 15, 2014 | Printronix T5000r Label Printer
Whe i boot up my printer it automaticaly prints out one label with leters on the top left corner and after that every other label i print out comes out with those leters can some one help me asap ...i need...
Sounds like a driver issue that is adding extra characters into the print script. Make sure your printer supports PostScript or PCL. PCL is the most common and works with all printer. PostScript requires a PostScript Chip installed in the printer. Download the latest driver either from the Printronix website or CNET.com
Oct 24, 2013 | Printronix T5000r Label Printer
122 execute form too wide for current page setting
Usually comes up when you are trying to print a label setup for a 300 dpi printer on a 200 dpi printer.
Oct 03, 2012 | Printronix T5000r Label Printer
A completed label comes out of the printer, then a blank label follows every time. How do I correct this problem?
make form in your pcside (printers and faxes in win xp) and select the appropriate form .
Jul 29, 2011 | Printronix T5000r Label Printer
Why would bar code print both vertically and
This is I think due to the data being sent to your printer. On a Z4m the width is 4 inch and whatever is beyond is not printed. On your Z6M the coordinates are valid so your printer will print the code.
Mar 26, 2010 | Zebra Z6M Thermal Label Printer
Printronix t5000r "GAP NOT DETECTED"
pls you can checked it by gap adjust lever. it is available in right side of printer.
Aug 17, 2009 | Printronix T5000r Label Printer
GAP NOT DETECTED ERROR ON PRINTRONIX T5000 PSN
My label printer quit printing the barcodes on the labels.
I am just getting a series of lines.
I have tried unplugging the machine and still have the same result.
I have tried to calibrate but that is not working either.
Thanks in advance for any suggestions.
Jul 21, 2008 | Printronix T5000r Label Printer
Printronix T5000r syntax to print
It's been several years since I had to program these.
try this
4 sets of double quotes
or this
double quote, single quote, single quote, double quote.
It's too bad I didn't have my manuals back when I was working for Pitney Bowes. If those don't work I'll see if I can Google the PCL manuals on Google.
Jul 14, 2008 | Printronix T5306 Thermal Label Printer
T5000 Thermal Printer
There are two guides on that machine.
One guide will make sure that the media is locked down and secured. if it isn't it will cause drifting.
There is also another guide around the thermal head before printing that guides the labels before it prints. It either white or or it could be a green color.
are you using the takeup roller on the printer to hold the wax paper? If you are is it straight on the take up roller?
Jun 11, 2008 | Printronix T5000 Thermal Printer
Printronix T5000r Label Printer Logo
259 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
