Frigidaire model ltf2940ee0
It will not spin. We replaced the control panel that controls spin and motor 140.00 part and it still wont spin. 14 months old.
  • thilges Jul 18, 2008
    Same washer, same problem. It will tumble and drain, but just won't spin. Wringing out the clothes by hand is getting tiresome.
    Problem Solver:
  • 12 Answers
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Stpe 6 Also access and save or print your : OWNERS GUIDE, TECK DATA, OPERATING INSTRUCTION, INSTALLATION INSTRUCTIONS and any other guides listed that are needed.
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for viewing and printing.
Thank you and good luck.
Posted on Jul 14, 2008
My frigidaire wont spin or wash
Remove the 2 screws on the top panel and remove the panel. Check the wiring connections on the control board.
Nov 11, 2012 | Frigidaire GLTF2940FE Front Load Washer,...
I have a Frigidaire front load washer. Model #: LTF2940EE0 Serial #: XC64319573 and it is not spinning on high speeds. It is spinning but only slow. When I put it on the rinse/spin cycle it spins in low...
Motor has some shorted windings. Timer switches to higher current for faster rotation and the thermal overload protection shuts the process off as the current is too high because of the shorted windings.
Oct 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
Model ltf2940ee0 spins slow
The problem may be with the spinning coil may be damaged kindly replace the motor
Dec 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer doesn't spin.
Try the motor controller, if you bought the unit before 2006 the part should have a 5 year warranty, check your manual. If not in Warranty the part is 178.99 average. The motor controller is in the back right corner of the machine. If you have a ohm meter check the motor for correct ohm readings, easy to do. The tech sheet inside the machine ( left side behind kick panel in a brown envelope) has the test procedure and ohm readings.
Jul 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Error 59 - Washer not spinning
find tech sheet at bottom of washer, behind kick panel on left and check error code there and if listed follow check for motor controller. if not draining either then check drain pump.
Mar 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Affinity washer not wanting to spin!
My Affinity washer quit spinning during the rinse cycle 14 months after we purchased the machine. We checked to make sure ithe drain was clear, and we tried changing the size of the loads. Nothing we tried worked. I was not getting any error codes on the control panel. We called a technician out to our house to see if it could be fixed. He diagnosed the problem as the control panel. We called Frigidaire to see if they would help us out with the cost of the repair since the machine was only 14 months old, even though our one year warranty had expired. They stated that they would not cover the replacement of the control panel. After the technician replaced the control panel and tried the machine, it still did not work. He called the Frigidaire tech support to find out why, and they told him that he needed to replace the door latch system, not the control panel. After he replaced the door latch the machine worked fine. When researching this problem online, I discovered that Frigidaire has had several problems with the door latch system on their front loading washing machines. They previously had a class action lawsuit due to this problem. When I found this out, I called Frigidaire to see if they would pay the repair bill we had incurred, even though our warranty had expired 2 months ago. After they contacted the technician that worked on our machine, Frigidaire decided that they would pay the cost of the replacement door latch and the labor fee. We had to pay for the cost of the initial service call. If you are having this problem, I would suggest that you contact Frigidaire. They will require that you have a diagnosis made by a certified technician. According to our technician, the flow chart for the Frigidaire front loading machines is inaccurate, so if they make an initital diagnosis of a faulty control panel you may want to have them contact Frigidaire tech support to double check the diagnosis. Frigidaire may help cover the cost of repair if your machine has a problem with the door latch.
Dec 18, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Front load washer wont spin
Open the rear panel and look for a broken belt and does the motor spins. In case motor doesn't spin, check on its tags for 115/220V. Let me know with your results,for further assistance if will be needed. Good luck!
Aug 28, 2007 | Frigidaire ATF6000ES Front Load Washer
Won't spin
Jessi, you need to call for factory service so you wont void the warranty. A couple of things could be going on here. The filter before the drain pump could be clogged with stuff preventing a high spin. Pressure switch wont allow a high spin if it detects water in the tub. The main control and motor control talk to each other and controls the spin. There could be a loose harness or poor connection at one of the boards. I would call for service, it won't cost you a cent...Catriver..post back.
Mar 15, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
421 people viewed this question
Top Washing Machines Experts
