Question about Arris SURFboard SB5120 Modem
Ethernet Port failure new router
I recently purchased and installed a Netgear router with my Surfboard modem and all was well for a week, then the ethernet cable running from my router to the desktop has apparently failed. Prior to that I had the modem with an ethernet cable going from the modem to the desktop. The new wireless router allows for 1 wireless laptop, 1 phone modem, and I have an ethernet cable connected to the desktop. Why would the laptop, phone, & desktop work all work well for a week, then all of the sudden the only thing not working is the desktop. The modem & router have to be working since the wireless laptop & phone modem are working. I can't figure out why the hard wired ethernet cable from the router to the desktop isn't working. Any ideas?
  • blindjbe Jul 15, 2008
    Thanks for the tip. I just found out what the problem was after much research. I will paste it below for anyone else experiencing similar problems.
    Overview : Microsoft Update KB951748 is known to cause loss of internet access for ZoneAlarm users on Windows XP/2000. Windows Vista users are not affected.
    Can you believe that?
    Here is the link that provides a solution to that problem:
    http://download.zonealarm.com/bin/free/p...
  • 3 Answers
Check the socket in either the router or the PC. I had the same problem, only with my modem. When I inspected the port, the pins were misaligned, causing it to drop a connection. I corrected mine with a screwdriver, which is not ideal but it works.
Posted on Jul 14, 2008
I want to plug in another wireless router into my surfboard modem and have the wireless router work as well as the surfboard. Is there a way to do this successfully?
Yes this is possiable. First you need to unplug the power to the Motorola and the new router. Second connect the ethernet cable from the Motorola to the internet port on your second router. This port may be colored in yellow, marked as modem, or the ethernet port by its self. Third connect a ethernet cable from the new router to a desktop or laptop this is only to configure the new router. Next power on the Motorola and wait for the online light to become solid. Then plug in the power to the new router. Give the router about two minutes to obtain ip address from the motorola then try to get on the internet with the pc connected with the ethernet cable. Now you can run the new router setup cd on the wired pc to setup router. Once completed remove ethernet cable to the pc and connect to either network you have and you are good to go. Any questions just ask.
Dec 30, 2010 | Arris SURFboard SBG900 Wireless Router...
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
How do i change my sb5101 motorola modem to bridge mode? so i can start using my netgear router
You shouldn't have to change anything except on the router. Cable to modem, Ethernet from the cable modem to wan port of the router, Lan ports to PC's. Instruct your router to use cable and not dsl, set acorrdingly to DHCP or static IP, set MTU to 1500 and go...
Jul 09, 2009 | Arris SURFboard® SB5101 Cable Modem
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
Wireless routers
Just plug the cable modem ethernet into the input to your router and you will be fine. Just remember, if you decide you want to make any changes to your router settings through your browser, make sure you hook up an ethernet line from your laptop to the router before making any changes. The reason for this is if you make a change in security settings on your router while wireless, the router will reboot and if your laptop did have the settings changed in it, you can be locked out.
Not that you can't get back in, but it is a pain to have to do.
Jan 14, 2008 | Arris SURFboard SB4200 Modem
Arris SURFboard SB5120 Modem Logo
448 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
