Download
the application. The Application is available through the BlackBerry
website (see Resources below). Have the download link sent to the email
address you use on your BlackBerry. Once the email arrives in your
BlackBerry inbox, click on the link provided and follow the prompts.
You will need to type in your Facebook user name and password to
complete the download process. Once the application is loaded you will
see a row of icons at the top of the screen.
Set
your Facebook status. Use the track ball to click on the first icon
(which looks like a person's silhouette with a phone) and update your
own status and see your friends' recent status updates. It may take a
minute to upload the status list so be patient.
Add
mobile photos. Use the track ball to click on the camera icon, and a
browser box will pop up with a camera option and the pictures from your
phone. If you pick the camera option it will take you into your camera,
and from there you can take a picture. Once the picture is taken, press
the "Menu" button. Select "Send to Facebook" from the pop-up menu and
that photo will post to your Facebook account. You can give the picture
a caption and "Tag" the photo before you upload it. If you want to post
a picture you have already taken, you can scroll through the photos in
the browser box. Select the picture, and it will give you the caption
and tag options.
See
your friends. The next icon will bring up your friends list. If you
highlight a friend's name and press the menu button, a menu will pop up
allowing you to poke him, write on his wall, send a message and view
his profile.
Add
friends, poke and write on walls. The next three icons are pretty self
explanatory. The silhouette with the "+ 1" allows you to send friend
invites. Just type in the email addresses and a message and click on
"Invite." The poke action is next on the icon list; just type in your
friend's name and click poke. The wall function is similar: Type in
your friend's name and then it will let you type a message.
Check
and send mail. From here you can see your Facebook Inbox and compose
messages. Only messages you have received since you added the
application will show up. To send a message, type in the name of the
recipient and an email box will pop up.
Get
your notifications. Each time a notification comes through, an alert
will be sent to your phone. To access the alert, go to the Facebook
icon on your menu. The notifications will be listed like your text
messages and emails. You can act directly on some of the notifications
from the listing. Other notifications require you to log in to the
mobile or Web versions of Facebook to continue.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
1-☺ 2-☻ 3-♥ 4-♦ 5-♣ 6-♠ 7-• 8-◘ 9-○ 10-◙ 11-♂ 12-♀ 13-♪ 14-♫ 15-☼ 16-► 17-◄ 18-↕ 19-‼ 20-¶ 21-§ 22-▬ 23-↨ 24-↑ 25-↓ 26-→ 27-← 28-∟ 29-↔ 30-▲ 31-▼ 32- nothing 33-! 34-" 35-# 36-$ 37-% 38-& 39-' 40-( 41-) 42-* 43-+ 44-, 45-- 46-. 47-/ 48-0 49-1 50-2 If you continue to press number combos then you will get different keys. You much hold down the alt key and type in a number combo at the same time.
I have a similar prob with this crappy lighter. The lighter & radio run off the same fuse. The fuse block is located near the hood release lever, under the dashboard towards the left side of the car. It's about 6" x 3" and white plastic. Can't miss it. The cover snaps off and the fuse is blue colored and 15 amp (says 15 on it).You can buy a pack of 5 of these at Walmart for about $3. Looking at the fuse block, go to the furthest left verticle row of fuses. It should be the last or next to last 15 amper from the bottom. You will need needle nose pliers to pull it out. Make sure ignition is off and start pulling 15 amp fuses, one at a time from the bottom then moving up and check to see if they are blown. You shouldn't have to pull more than 4 of them to find it. What I plan to do is splice and aftermarket (Radio Shack) inline fuse into the hot or + side of the lighter wires. This way, hopefully if the lighter shorts, it won't take the clock and radio with it and will be much easier to replace the little "barrel" style fuse. Just make sure it's 15 amps. Hope this helps. ♥♥♥♥ LJA
there is an attack which is called guard break. gaara has the shikaku demon level1 in him ensuring any attack will be protected by his mothers spirit in the sand. you can use down,circle to break the guard. this is where you use your secret technique!! Triangl,circle. Or you could repeatedly use the grab move which is back arrow,(away from gaara),circle. Also save your skills for gaara.
