i just bought this thing ive upgraded from a 250 watt amp to the 600 hooked i changed the gage of the wire to 8 (from the battery) and hooked everything up the exact same but now im not getting any power to the amp any suggestions.
A couple of things you can try: 1. check for B+12 on the 1st and 2nd terminals of the Power Connector using a voltmeter; 2. temporarily put a jumper on the 1st & 2nd terminal of the Power Connector; 3. the usual, check for loose connection, fuses, wires, connectors.
if there is +12 on both terminal and amp is still dead, then it is internal; if there is +12 on terminal 2 but none on 1, then it is the wiring from the head unit or the trigger of the head unit that is the issue;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
