7KG WD-8050FH LG Clean Master Front Loader (5 stars) No Drain ....won't drain or spin
  • Anonymous Nov 06, 2008
    My machine will not wash or spin, but you can get it pump out the water
  • Anonymous Feb 09, 2009
    My machine washes & spins but won't drain. I'm fairly positive its the pump! It shouldn't be more the $80 or $90 for the part then there's the cost of labour to install. :-( Still cheaper than a replacement!
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Posted on Aug 14, 2010
I have LG Washing Machine and the water does not drain whilst the machine is washing. What can be wrong?
problem is with main board MOSFET ,FET or Transistor , that are not switching your drain pump at right time , if your'e pump is fine, , you should check drain pump separately by giving it separate supply. ( see its data sheet for power )
Dec 22, 2014 | LG Washing Machines
I have a LG WD 1238C Front Loader Washing Machine and the display has a CL on it.
Remove power for some time , allow the power to drain off the memory and see if the display is clear. If not hold the start button and switch on power. Check the inlet and drain filter , free water flow, if not remove and clean.
Nov 01, 2013 | LG WD-1280FHD Front Load Washer
LG Intellowasher 7kg WD-1255FHB not draining properly
try draining to a different place . my system does not drain into something that can get plugged with leaves
Nov 01, 2017 | LG Washing Machines
I have an LG front loader - model WD - 804 90TP and the machine is working but it gets down to 6 mins to run the spin cycle and then goes up to 14 mins and then back down again and carries on in that cycle...
You need to check the inlet valve for good flow of the water as a SLOW water pressure can increase the timing for rinse and spin.
Similarily the DRAIN pump/valve must be checked as if this is clogged then the drain flow will be LOW and the timing will extend for full drain. Remove and clean the drain pump and it can be the reason that the clothes are still wet.
Finally check on the controller for the proper timing of the cycle.
Tips on Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Sep 15, 2011 | LG Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
LG front loader WD 8050FH
Be sure to remove the pin catcher assembly, at the bottom front right of the machine. Usually a small door at lower right side. Tip machine back and unscrew the large handle and remove to clean.
Jan 02, 2010 | LG WM2487H Front Load Washer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washing Machines Logo
1,052 people viewed this question
Top Washing Machines Experts
