Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Fuses in microwave
I saw the comment, have not figured out how to get the microwave out yet to find the fuses but we will just start to unscrew things and hopefully find something! Thank you.
    Problem Solver:
  • 5 Answers
There is a large fuse behind the control panel and a smaller one on the right top side of the microwave. You have to pull the unit partially out to access this. Here is a link that directs you to a repair manual with detailed instructions how to do this.
http://applianceguru.com/view_topic.php?id=16293&forum_id=1&jump_to=97654
Scroll down and find the pdf file. If it still doesn't work you may have to replace the door latch switches, one on the left and two on the right. You can find the fuses at Lowes or Home Depot. The switches have to be ordered from here:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KEMC308
Posted on Aug 08, 2010
    President:
  • 1,314 Answers
Send me an email b4829@yahoo.com
Posted on Jul 14, 2008
Hello we have bosch hbc 86 and every time i want to turn on the microwave it suddenly stops, even when im trying to defrost,it starts and then in 3 seconds it turns off, please do you have a solution for...
My HBC 86 showed this behavior, after a fuse for the microwave operations was blown (remove the top cover and you will see it on a board close to the door). It's an 8A, medium speed. There might be different reasons, why the fuse is blown. In my case, the switches that detect whether the oven door is closed or open caused the problem. There are two connected with the microwave, one on the left (a bipolar switch) and another on the right. The switches will cause a short-circuit (and thus a blown fuse), if the left one detects an open door and the right one a closed door - it's an additional security feature. The problem can be caused by a blocked or slowly reacting switch. You might want to clean/replace the switches and/or put the right switch as far as possible away from the door so that it detects a close later (and open earlier). A good thing for testing: the problem occurs without actually starting the microwave.
Oct 15, 2010 | Bosch HBC 86Q650B Electric Single Oven
I can set the power and the time but when start is pressed the microwave runs but the table does not rotate
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 14, 2010 | Ovens
LG Microwave oven: start button not working pls guide
heatman101
z
Sep 30, 2010 | LG Ovens
I have a kenmore electric oven and I saw sparks flying when I was cooking lastnight. It looked like the coil may have a hole in it. When I unscrewed the coil it began shooting sparks when I pulled on it....
first thing u need to do is get the power switched off. if u cannot get at the plug trip the switch in your main fuse box.
u can then remove the element safely and replace it
never work on a live appliance
Sep 28, 2010 | Ovens
Microwave has no power. It is a combo oven/microwave built-in oven and the microwave has no display or power to the interior light. Is there a fuse location or a way to re-set the oven?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
uu
Sep 27, 2010 | Ovens
Microwave stopped working after an apparent surge. Tried unplugging, plugging back in, checked breaker panel. Electrical for the microwave works. Think it must be a fuse in the microwave b;own? If so,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 12, 2010 | Ovens
Microwave daewoo model: Kor-1a4H is not making any thing hot or warm, watis possible fault? thanks for your support
heatman101
Sep 03, 2010 | Ovens
Hello my power has completely failed on my microwave. It is really 2 years old. We check the fuses and everything looks good please help us out. It is a frigidaire f m v 158 f m b. You have any...
We are fixya try to solve problems only on line. I can guide you and give some suggestions.
If the fuse is OK then if there must be three things you can check up.
Put in a glass of water, set the time to about 3 minutes and switch ON in low power .
Now take care when touching the circuits as there can be high voltage and it is not recomended for a novice to do this work as in the presence of microwave there is danger of burning or skin damage.
Check the Magnetron and the capacitor along the circuit. make sure the transformer is connected and the inline fuse is OK.
make sure that the limit switch of the door is correct. If not open and close for the switch to latch on so that the ccircuit completes for switching the microwave.
Next finally check on the TOC- temperature cut offf contact- a small round component on the side of the cabin.
Check this and comment. Dont forget to rate my advice.
Aug 31, 2010 | Ovens
Microwave oven cuts out after pie inside catches fire.
When you mention the fuse, if you mean the one inside the microwave, then your magnetron is probably damaged and you should just get a new microwave.
If you're talking about the fuse in the electrical fusebox, then you could try opening the case of the microwave and finding the fuse inside. If you aren't familiar with working on HIGH VOLTAGE, then don't do this, take it to a service tech. But if it's out of warrenty and you are experience with working safely, you can look for a fuse inside the unit. As I said above, though if you do change it and the oven still won't work, your tube is probably dead and it's not worth the money to get a replacement part.
But again, I'll stress that the microwave has a HIGH VOLTAGE POWER SUPPLY inside, and if you aren't familiar with working on things like this then just take it to an appliance repair store.
Feb 16, 2010 | AEG Ovens
KitchenAid KEMC308KSS02 Microwave Error
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
Jun 14, 2008 | KitchenAid KEMC308 Electric Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
127 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
