Question about Maytag Dryers
How do I install the idler wheel for the belt on my Maytag Dryer
    President:
  • 1,314 Answers
Lookm on the front panel under the ridge on the body where the door is you will see two screws there remove them and pull the panel out from the bottom that should give you acess to the idler pully
Posted on Jul 14, 2008
Need to put belt back on the dryer
Get the drum out and clean up the area inside the dryer. Check the blower wheel is tight on the motor shaft. Oil the rollers and idler with zoomspout oil. Place the new belt onto the drum at the mark where the old one ran along and use the belt to set the drum back over into the dryer. Remove that brace number 24 so that you can get your arm in there. It is better if you have the dryer on a tailgate or appliance platform. Reach in there with your left hand and loop the belt onto the motor as you raise up on the idler. Release the idler to where its spring action will hold the belt to the motor and drum.Then slowly turn the dryer to make sure the belt is in the mark on the drum and is not twisted.
I have some Maytag type dryer service manuals HERE
Dryer belt routing information is HERE
Dec 02, 2010 | Magic Chef CYE2000 Electric Commercial...
Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Apr 09, 2010 | Maytag Dryers
A constant clicking noise near the motor of my maytag dryer. seems something is slipping as occasionally the drum and belt slow down
It sounds as if the idler bearing has started to fail see this picture http://sites.google.com/site/sublimeappliancerepair/_/rsrc/1246721031553/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info/Norge%20dryer%20with%20drum%20removed.jpg
The idler pulley in the picture is behind the motor.
I would check the ilder pulley to see if it rotates freely and does not have any odd side to side movements. If it does then replace the idler pulley and belt.
Belt: http://www.appliancepartspros.com/part_details.aspx?part_id=4043963&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d47809%26diagram_id%3d681078
NOTE: Before you remove the idler pulley and belt note carefully the installation position of the belt, idler arm, spring and the idler pulley. For a first timer trying to do this it can be quite frustrating to get them all positioned correctly.
Idler pulley:
http://www.appliancepartspros.com/part_details.aspx?part_id=4373393&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d49146%26diagram_id%3d673577
I hope this has been useful information to you. Good day.
Jan 06, 2010 | Washing Machines
Installing a belt on a maytag dryer the belt seem to be too big what's the solution
you probably don't have it strung right thru the idler pulley by the motor, thats if you have the right length belt to start with,measure it with the old one to be sure
Oct 26, 2009 | Maytag SDE5401AYW Electric Dryer
Install dyer belt MAYTAG
Hello there
Here is a detailed instruction for you ok
  1. Remove the two screws that hold the control console to the dryer; they are located on each end of the console. Turn the control console forward onto its face. Disconnect the wiring harness from the dryer to the console. Press in on the locking tab and pull the connectors apart. Set the control panel out of your work area. To remove the top, insert a putty knife between the front and top panels. Locate the retaining clip and push in on it to release the corner of the top panel. Lift up on the corner and release the opposite retaining clip. Set the top panel out of the way. Two screws that attach the front panel to the sides are located at the top corners. Remove the screws and swing the top of the front panel out so that you can access the door switch wiring harness. Disconnect the wiring harness from the door switch and lift the front panel away from the dryer.
  2. Replace the Belt
  3. Locate the idler pulley by reaching behind the drum and motor assembly. Using your hand, push the idler pulley to the left to release tension on the belt2.gif. Notice the routing of the belt around the motor and idler arm for reference when attaching the new belt. Remove the belt from the motor pulley. Lift up on the drum slightly and remove the belt from the drum.
    With the rib side pointed inward, lift the drum up and set the belt around the drum. Route the belt through the motor pulley and idler pulley. Pull the idler pulley to the right to reapply tension to the belt. ok?
  4. not too hard
  5. hope this is verry helpful for you
  6. Best regards MIke
Oct 15, 2009 | Maytag PYE4500AY Gas Dryer
Belt installation
HI, Looking at the idler assembly from the back, move the idler wheel to the left (spring loaded).
Slip the belt on the motor pulley with ribs touching pulley. Now let the idler pulley rest againdt the back side of the belt.
I hope this helps you.
Please let me know if I can help further.
Vic
May 23, 2009 | GE DBL333EA Electric Dryer
Dryer belt slack
Start from the motor threaded shaft. Then pull out the Idler pulley so that the back of the belt will lying on the Idler pulley in upright position. that is all.
Mar 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Which wa does the belt on a Maytag Atlantis dryer run around the motor and idler pulley. I have the belt groove side down, which is the way it goes in the Atlantis, but I couldn't find a schematic for the...
Hi you're correct in putting it groove side down. Now make a loop, like when you first started tying your shoes with the slack around the drum. Push the entire loop just beneath the idler pulley through the metal channel and apply pressure to the idler pulley assembly. pushing it towards the motor pulley until you can get the loop you are holding over the motor pulley and Waa Laa you've installed your new belt. Good Luck!
Dec 10, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer keeps breaking belts this is 2 belts in less than 2 months what is causing this to happen
Check the idler pulley, if not turning freely, the belt may have excessive friction against pulley wheel, overheating and failing. Or dryer drum seals may have failed causing excessive tension on belt.
Jun 18, 2008 | Maytag Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
