My tv made a popping sound then the color started to mix then went black and is making a humming soun. it sounds like a jammed cd in a player
  • 8,617 Answers
I would need the model number of your set to even begin to help you with a possible solution. please respond to this same post
Posted on Jul 14, 2008
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Oct 14, 2010 | Samsung HL-R5656W 56" DLP HDTV
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Screen went B&W and I hear a loud humming noise from the TV...
Hi John,
If you are hearing this noises,that's your Color Wheel.
The reason fot that is because your color wheel spins 5000rpms(revolution per minute) and something that modifies the balance if the disc can cause different things.Unfortunately in order to check if your color wheel is working properly you need to open your TV and physically check out.
Grinding= Most probably the color disc is broken and you need to replace it.
Spinning / Buzzing = The bearing of the wheel is loose and is loosing its balance,eventually it will brake.
The best thing to do is to take the color wheel out and spin it ,if you feel that the disc kind of wobbles or doesn't spin smoothly you have to replace it.
You can check DM they have very good prices
http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20color%20whee l?click=52978
I hope this will help,please keep us posted
Oct 05, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Same humming , but then goes off.
Color Wheel it is you can get one for around 95.00 up depend s on Part# BP96-00674A cost 113.69 Call Encompass Electronics 1-800-638-3328.Just looked it up they have it.
Sep 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Bizzare problem with the color
Sounds like something may be wrong with your cable line might need to have it checked.
Aug 19, 2009 | Sony KV-32FS13 TV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Mitsubishi hd 1080 tv humming and blurred words/ bight colors
check the capasitor near the plyback value 250 volts and also the B+ capasitor
Oct 01, 2008 | Mitsubishi WS-55807 TV
Televison & Video Logo
Top Televison & Video Experts
