Question about Fujitsu Siemens Siemens B772-1 17" CRT Monitor
Automatically changing colors red & yellow - Fujitsu Siemens Siemens B772-1 17" CRT Monitor
    Scholar:
  • 140 Answers
This is a simple problem just change the data cable of the monitor . data cable is the cable attached with the vga of the cpu.
Posted on Jan 14, 2011
SOURCE:
Connecting DVD player to spectre ledTV
It should be hooked up just like any other tv would be. The output of the DVD should match the input you're going to use on the tv. If you're going to use an HDMI connection then both units have to have HDMI connections. If not HDMI, then either composite connections (RCA plugs that are colored red, white and yellow). Each color go from and to the same color on each unit. You may also have an 'S' video (usually yellow colored). If you use this connection then don't use the RCA yellow connection. The S video connection has a better picture than the RCA connection. Either way, you still have to use the red & white (or black) RCA connections for the left & right audio. However, if you use the HDMI connector then you don't need the red & white audio connections because audio is already in the HDMI connection.
Aug 18, 2017 | Televison & Video
How do I connect my tv to DVD.
There should be a red,white & yellow phono jack's & ports on tv & dvd hook up by color. yellow is pix red & white are sound.
Feb 21, 2015 | Proscan Televison & Video
I need to know what the six wires that are on one plugin goes to by the color of each seperate wire for the drivers side electric seat. The Colors are: Black, Red & Black, Yellow & Green, Yellow...
That connector is for the lumbar support in the seat. The wires are as follows:
Black - Ground, ends at left side under the dash.
Red and Black - Power to circuit fromk fusible link
Yellow and Green - Lumbar support, Push out
Red and Yellow - Lumbar support, Release in
Yellow and Blue - Side lumbar support, Spread out
Yellow, Should be Yellow and White- Side lumbar support, Close in
Hope this helps. Good Luck!
Apr 29, 2011 | 1994 Mitsubishi 3000GT
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
Red an yellow and white cables plug in where
OK, they wire color to color at each unit, the Yellow, is VIDEO. Out, or In. The Other Two are AUDIO, the Red & White are L & R Stereo Sound Out, Or IN. depending on how marked at rear of unit.
Jun 15, 2010 | RCA E13320 13" TV
I have an Envision AOC 32 tv monitor and want to hook my WII up to it, It has yellow white and red wires. The back of the monitor has HMDI, PC Cable, and coax connectors. It also has speaker out puts and...
Yellow Is VIDEO, Red & White is your AUDIO. (Stereo). They should go color to color on the TV's AV input. This is AV, and you use 3 wires to connect this way.
The Red, Green, & Blue, is called COMPONENT, & is ONLY VIDEO, the AUDIO, still must use Red & White. So to connect with Component you use 5 wires, altogether, 3 for Video, 2 for Audio.
Plug them in color to color & choose the right INPUT on the TV, and turn on your input device.
Feb 26, 2010 | Envision L32W761 32 in. LCD TV
I need wiring color code for 97 Ford Expedition
red/yellow leads from the 5amp fuse #29 and red/white leads from 5amp fuse #2. Both of these run into the instrument panel. Let me know if you need more info.
Jan 25, 2010 | 1997 Ford Expedition
Can I connect this player to a hdtv?or do I need additional cables because it is only playing in black and white
Basically -yes; the picture quality may not be to your liking (there are ways to minimize this).
First let's get the units 'talking' to each other. There is no info showing re: the HDTV you're using, so I'll keep things generic.
Easiest: if both units have RF cable connectors (the old screw in cable TV types), hook 'em up with a short piece of cable, and make sure that the channels out & in match (they are ch. 3 or 4).
Next up: Look for RCA jacks for out & in on both units. The colors will be yellow, red & white. The yellow is video, the red & white are audio (lt. & rt. channels) Check the jack's labels to be sure. Fire up the player, and run the set up- Sources In on the TV, and follow the prompts to get both sources 'seeing' each other.
Better quality: Look for S Video connectors on both units (they will be round with 1 square & 3-6 round pins). If you have these & a cable, hook 'em up; you'll also have to do seperate audio connections too. With S video you'll have to check the TV's source menu, and go from there.
Best quality (short of HDMI): at the Video Output & Inputs of both units see if there are 3 RCA jacks (usually grouped & 1ea yellow, green & red (colors can vary due units ages)), match 'em up red->red, etc. this is important since this is how the colors will be displayed!! Now You also have to hook up your audio too. Again, fire up both units, with this type connection the TV may automatically detect the new input; otherwise let the units detect each other and go from there.
Out of the methods above, only the 'S' Video is a specialized cable; for the RCA type cables, regular Audio type cables will work. If there is a lot of RF interferance upgrading to better quality and shielded cables may be necessary.
I hope this helps out.
Regards.
Sep 23, 2009 | Durabrand DVD-1002 DVD Player
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Open Questions:
See all Fujitsu Siemens Siemens B772-1 17" CRT Monitor Questions
Fujitsu Siemens Siemens B772-1 17" CRT Monitor Logo
202 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
