Question about Sony Televison & Video
Rainbows across screen
I have a 58" wide screen projection tv. Last year we had a tech. come out because we had a rainbow going across the screen. He did a minor adjustment and fixed the problem. We have the rainbow again and the screen goes solid light green where you can't see anything. Can't I replace the part with your guidance?
  • golf19 Jul 15, 2008
    The speaker is four feet away and the rainbow lines are still there. After some time the screen goes light green. Last year the technician took the front cover of the tv off and adjusted something. He also told me the replacement part would cost around 75.00. This is a projection tv.
  • golf19 Jul 18, 2008
    I looked through all the popular mechanic articles and there is not any article pertaining to my problem.
    Master:
  • 726 Answers
On a projection tv as these guys just guessing there is no tubes in side a tv like yours same as mine there is 3 liquid filled bulbs and one big arse mirror your problem will be one of the bulgs leaking,blown,or just failed these are roughly 30 to 80 dollars each u wont have a circut board problem t will not cause this only the bulbs will and on a projction u can put speakers close as u want
Posted on Jul 18, 2008
  • Sony Master
  • 6,487 Answers
Check this link for some tips http://www.popularmechanics.com/technology/upgrade/2826881.html
Hope that helps.........
Posted on Jul 15, 2008
  • 78 Answers
IF this is a projection tv of tube nature, you need the projection tubes degaussed. IF it is solid state, you have circuit board problems and that can get expensive...if not impossible when compared to the price of a new TV. BE very carefull of speaker placement near these tube if it is a projection tube type...get the speakers away from the sides of the tv, Turn it on and off several times. (it degausses itself everytime it is turned on)..and see if you see a lessening of the effect...if you do, then with time, this will go away.
Hope this Helped. -CA
Posted on Jul 14, 2008
I have a narrow green band across the top of the screen similar to a rainbow -also Ex: most of what appears on the screen is double vision. thankyou.karen t.v. is approximately 8 years old
Your TV needs the convergence ICs replaced .
Not something you can do, techs usually charge about $300-$400 to replace them in your house.
I may be worth fixing if you can find a reliable tech in your area.
best of luck
Dec 17, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Fixing RCA TV Model R52WM24YX61 with rainbows
The ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com should solve that issue. Instructions are included.
May 07, 2010 | RCA R52WM24 52" HDTV Projection Television
There are flickering, rainbow-like color bands running across the screen, especially in the component inputs, not so much using the HDMI input, but still there.
Hi,if your tv is and Lcd rear projection it will be the light engine that needs replacement.Because lcd technology uses 3 chips green,red and blue that create the image and colors.When they start to fail you will get what you are getting color discoloration and rainbows.If your tv is DLp it will be the dmd chips which basically its like the lcd chips but instead of 3 chips its only one that creates the image.Hope this works God bless you!
Oct 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Rainbow screen, no color, tv fell over
ur tv needs to be degaused using a degausing wand or ring. mos def needs to be taken to a professional to be done.
May 18, 2009 | Zenith SY2765S TV
I have a 3 year old mitsubishi wd-52526 lcd projector tv that is starting to have some focus/image alignment issues - in general picture is a little out of focus and there are rainbows around things at the...
the differnt guns are out of alignment. Your tv has 3 lcd screens, a red, green and blue one what overlay to form the image. Sometimes they move slightly for what ever reason and that causes the rainbow and out of focus picture. Its something that a trained pro should do but is a cheap fix and won't set you back too much
Oct 20, 2008 | Mitsubishi Televison & Video
Red and green shadows on picture looks like 3D
blue and green like rainbows across the TV
Sep 14, 2008 | Televison & Video
Sony KP-57WS510 rainbows and arches
no the shape doesnt matter as long as the STK numbers are the same. I would make sure that the replacements are origional sanyo ICs as often the cheaper versions do not last very long.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Digital Static
try changing you sky box.. or freeview.. i did.. no problems now
Aug 07, 2007 | LG 32LC2D Television
Televison & Video Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
