Question about ASUS P4P800-MX Motherboard
Will not power-up after a shut down unless the CMOS is cleared.
I'm forced to clear the CMOS after a shutdown to get the PC to power up. I'm clearing the CMOS by turning off the PS, removing the battery and moving the jumper to pins 2-3. After waiting about 10 seconds, the battery is re-installed and the jumper is set back to pins 1-2 and the PS is turned back on. On boot up, F2 is required to reset the BIOS; the PC will then boot correctly.
If I leave the battery out and perform a shutdown, the PC will power up without clearing the CMOS as state above, but I still have to press F2 to continue booting.
I have replaced the battery with a new one, but problem continues to occur. If I restart instead of shutdown from within Windows, there's no problem.
Any idea what's causing this to happen?
  • 3 more comments
  • Gary O Jul 14, 2008
    Custom built. What info do you need?
    The problem has been resolved.
    I discovered that the CMOS jumper was missing the internal metal
    connector. It must of fell out of the plastic housing somehow.
    Replacing the jumper resolved the problem.
    What are the odds of something like this happening?
  • Michael Ortega
    Michael Ortega May 11, 2010
    I think we could've been here for awhile trying to find that one. Good job for finding it.
    MO
  • Michael Ortega
    What's the model of the motherboard itself?
    Was the computer ever functioning properly without the startup annoyance?
  • Michael Ortega
    What's the computer model?
    Sergeant:
  • 284 Answers
Try swapping the Ram Chips "Memory" try running it with less memory or if you have multi chips take a few out and run it
Good luck
Please rate US! thanks
Posted on Jul 14, 2008
Remove versa 6060 bios password
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 13, 2012 | NEC Versa 6060 Notebook
Lennovo g570 bios cmos not responding for enabling password
Aug 11, 2012 | Lenovo G570 Notebook
Lenovo desktop 3282 beeps twice then 5 times and goes no further
Aug 01, 2012 | Lenovo Computers & Internet
Asus will not turn off after shutdown
All these things point to the bios. You need to go to the Asus site for that motherboard and download an upgraded bios. There will be directions there on how to update your bios, probably both from Windows and from the system prompt.
Apr 19, 2012 | ASUS P5AD2-E Deluxe Motherboard
Li m runing window 7 operating system i forget my bios password so help me to install window in my system
First you have to reset your bios password relax , you can do it. It just take time.There are two ways to approach forcing the Bios/CMOS to be reset to its default values: Option #1: Mechanically, by removing all power to the Bios/CMOS thereby forcing it to reset itself to its stored defaults, which include no password or the default password employed by the Bios manufacturer, and Option #2: Using a program to either locate and identify the password and reveal it to you or erasing the password entirely. These are referred to as password by-pass utilities or cracks. Let's look at Option #1 first, and then move on to Option #2 if necessary.Most motherboards manufactured over the last decade or more use a battery to sustain the dynamic Bios/CMOS settings for the motherboards PROM chip. These dynamic settings are those manually set by either the computers manufacturer or you, the user. There are two ways to erase these dynamic settings, by either resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper), or by physically remove the power from the computer (disconnecting the power plug) and then removing a battery (used to maintain power to the PROM chip that contains the Bios/CMOS information) from the motherboard.Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.But do not forget to put it back at its same pin as before.
Aug 19, 2011 | Computers & Internet
Trying to enter BIOS on Gateway 7330GZ and it is requesting a password on a old dos type screen
To reset the bios you must clear the CMOS
By either resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper), or by physically remove the power from the computer (disconnecting the power plug) and then removing a battery (used to maintain power to the PROM chip that contains the Bios/CMOS information) from the motherboard.
If the "Clear CMOS" jumpers are not present or not available:
Shut down the computer and disconnect the power plug. Locate, if possible, the instruction booklet for your motherboard. Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
for further information read
http://www.dewassoc.com/support/bios/bios_password.htm
May 02, 2011 | Gateway 7330GZ Notebook
Is there a jumper to clear CMOS on the MCP61SM-AS motherboard?
DEAR IF YOU DONOT KNOW ABOUT THE JUMPER YOU WILL SEE A CELL .A CELL OF THE SIZE OF A COIN OR PEPSI LID. PUT IT OUT BUT DONOT FORGET TO SWITCH OFF THE MAIN(I DONOT MEAN TO SHUTDOWN THE PC I MEAN SHUTDOWN THE PC AND ALSO UNPLUG THE MAIN POWER SUPPLY) NOW PUT OUT THE CELL AND PUT IT AGAIN IN ITS LOCATION CARFULLY AFTER A MINUTE AND YOU WILL SEE THAT THE CMOS IS CLEARED NOW
Feb 06, 2011 | EliteGroup ECS GeForce6100SM-M (1.0)...
Won't shut down completely
If shutting down XP takes what seems to be an inordinate amount of time, here are a couple of steps you can take to speed up the shutdown process:
  • Don't have XP clear your paging file at shutdown. For security reasons, you can have XP clear your paging file (pagefile.sys) of its contents whenever you shut down. Your paging file is used to store temporary files and data, but when your system shuts down, information stays in the file. Some people prefer to have the paging file cleared at shutdown because sensitive information such as unencrypted passwords sometimes ends up in the file. However, clearing the paging file can slow shutdown times significantly, so if extreme security isn't a high priority, you might not want to clear it. To shut down XP without clearing your paging file, run the Registry Editor (click Start > Run, then type regedit in the Run box) and go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
  • Change the value of ClearPageFileAtShutdown to 0. Close the Registry, and restart your computer. Whenever you turn off XP from now on, the paging file won't be cleared, and you should be able to shut down more quickly.
    Note: Please be careful when editing the Registry; you can do a lot of damage here. Don't change or delete anything unless you know exactly what it is.
Apr 13, 2009 | Computers & Internet
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
After force shutdown keyboard, mouse USB touchpad are not working
inside xp you can go to the hardware section and uninstall the usb drivers. when you reboot the drivers refresh for the usb and you can continue as usual.
Mar 11, 2009 | Acer Aspire 5100 Notebook
ASUS P4P800-MX Motherboard Logo
321 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
