Question about Kenmore 46462 Front Load Washer
Kenmore HE2plus i have a problem the washer keeps coming up F 22
    Genius:
  • 1,028 Answers
The f20 seris usually means a water problem ..ckd both faucets are fully on and connected correctly ckd screens in connection at end where hooks to washer.screens are inside connection be sure they are clean has also been a problem with water level switch remove top to locate it on right side with small hose attached
Posted on Jul 14, 2008
2 Suggested Answers
  • 382 Answers
SOURCE: kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Posted on Dec 16, 2009
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
Dec 11, 2011 | Kenmore Washing Machines
F-21 error code, washer stops
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris.
Thank you !!
Jul 13, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore (HE2PLUS) front-loading washer leaking out the front door,,,,,,,,C. Pellecer
check the inner door seal it may be damaged that may be why it is leaking
Kenmore He2Plus Washer: Controls Locked button lites up & beeps
plug it back in and there should be a buttong somwhere toward the corner and in small lettering"un-lock/lock" hold that button for 5 secs and see if it un-locks the board. if it dont the your board might be bad....hopefully this helps
Jul 30, 2009 | Washing Machines
What is code f21 on kenmore he2plus washer and how do i fix it
It means you have a drain problem. It could be a pressure switch or the drain filter plugged.
Jul 14, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer he2plus
My HE2 Plus vibrates terrible. Moves all over the place. Anyone else with this problem
Jan 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
73 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
