I dont know how to hook up a dvd player - Televison & Video
    Scholar:
  • 43 Answers
Depending on the model of DVD player and the TV you are trying to connect it to you have various inputs and outputs.
If your have an HD (High Definition) DVD Player and a HD TV the best input to use is HDMI. Both device would have an HDMI interface whereby you could connect them together.
If you have a standard DVD Player you have usually 3 other input/output options, RCA, S-Video, and Component. Your RCA jacks are colored Red, Yellow, and White. Your S-Video is a larger circular jack with several pins. The Component cable has Red, Green, and Blue.
Of the three above the Component Cable connection is going to give you best picture quality. S-Video is second and RCA is third. You just need to match up the connectors on your TV and DVD and get the cable that accommodates the best picture quality. Again for clarification below are the interface options for best quality to poorest:
1. HDMI
2. Component
3. S-Video
4. RCA
Hope this helps.
MO
Posted on Jul 14, 2008
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
How to connect dvp3266 with tv?
If you dont have the user manual you can get one on-line at http://www.p4c.philips.com/files/d/dvp3266_94/dvp3266_94_dfu_eng.pdf and it will show you how to hook it up to most TVs. Would have to know what TV your hooking it up to, for further assistance.
Sep 06, 2009 | Philips DVP5990 DVD Player
I have a coby dvd player hooked up to my new Vizio television. I don't know why, but when I play movies on the dvd player, they only play in black and white. I don't even pretend to know anything...
Press N/P button on remote, if that dont work, go into the Setup Menu and do a DEFAULT. If either of those dont work, check to make sure your video cable is in the correct location.
If your in U.S., should always be on NTSC
If outside of U.S., you would select PAL
Jun 15, 2009 | Coby DVD-536
Problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Mar 17, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Hooking up Pioneer DV 250 DVD player through Directv Satelite Receiver
i dont know what hooks up were on my tv i have rca jacks but cant seem to get it all to play , hell i dont even know what channle to put the tv on, i do have a cable box to
Sep 17, 2008 | Pioneer DV-250
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Aug 18, 2008 | iLO DVDR05 DVD Recorder
Games
try going to radio shack and asking someone who works there to help find a AV female to AV input chord.
hook up the device that has a male AV out plug to the AV female plug and hhok it up to your DVD player
Dec 24, 2007 | Mintek MDP-1770 Portable DVD Player
Make my dvd work
 Did you hook up the wire harness correctly? Because you are not receiving power to the monitor. check these connections again. Maybe you have the wrong harness. Are you using the one from your car or DVD player? Did you splice the wires together? Do you have a correct color scheme to your vehicles wiring?
you may also need to bypass the monitor in order to view the screen while driving (if you're a rebel against johnny law)
Oct 29, 2007 | Pioneer AVIC-D3 Car DVD Player
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
