Question about HP Computers & Internet
RE: hp 510n need to reset to new settings
Help me
how do I reset my hp 510 n to out of the box restoration?
    Problem Solver:
  • 14 Answers
You have to use the HP Backup and Restore utilities. There are two ways to access this - either from within the operating system go to Start, All Programs, HP Backup and Restore and run the wizard which will guide you through the process.
If your operating system is not functioning, you can try repeatedly tapping the F11 key as soon as the system boots up to go into the HP Backup and Restore utilities on the recovery partition.
If neither one of those options is available, perhaps because the partition was removed or is corrupted or the hard drive was replaced, you will need to use the system restore CDs that came with the system. If you did not receive system restore CDs with the system, you were expected to make a set using the HP Backup and Restore utility when you first set up your computer. These CD's are available if you do not have them from HP - you will have to call 1-800-HPINVENT to get the restore CD kit.
Posted on Jul 14, 2008
My 510 sync master monitor comes on when i press the power button but goes right back off
Any FIFTEEN-inch screen is very old.
Responsibly recycle it, and buy a new 19 or 21 inch screen.
Your eyes will thank you for having the much-bigger screen.
Oct 30, 2014 | Samsung SyncMaster 510N 15" LCD Monitor
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
My SyncMaster 510 displays jagged pictures
sir, 510n monitor turn on ok but after sometime white screen. any soloution plz..............
May 24, 2010 | Samsung SyncMaster 510N 15" LCD Monitor
I received a Vivtar digital recorder 510N and lost
heres the manual
on the vivitar website, the 510n has no downloads so i went to the 510 and the manual there was for the 510n. hope this helps
Apr 14, 2010 | Cameras
No display in monitor
Was the monitor tested, that it is working before it was delivered to you? Because it was still under warranty. If your system unit open ( a beep sound hear ) wihen your new monitor was attached only that their is no display but the monitor has a power, means it needs a video card with a driver to be installed. If you have another monitor try it to your computer if the problem still the same.
That's all
Nov 19, 2008 | Samsung 510N 15" Flat Panel LCD Monitor
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Its a HP iPAQ 510 Voice Messenger and i want to reset it to its factory settings as if it was brand new
Hello haccstk
HERE are HP's instructions for performing both a "soft" and a "hard" reset of your HP iPAQ 510.
If you need any assistance at all w/ this process, just let us know. We'll be happy to help you.
If you have ANY other questions, etc on this topic, just post back here w/ them. As I said, we'll be happy to continue to help.
If I answered your question and you have no other questions or need of our assistance on this topic...
...would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
Thank you once again for using FixYa! Have a beautiful day.
BJ @:)
Apr 20, 2008 | LG KU990 Viewty
check which function key at top looks like a number key pad or has written in gray, num lk. Mine is F11 press the FN + that key
Apr 18, 2008 | HP 510 Notebook
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Computers & Internet Logo
534 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
