Question about Mitsubishi VS-4544 45" TV
Mitusbushi VS-4544 Horizontal lines then looses picture.
Hello All,
I have a Mitsubishi VS-4544 that recently started having some intermittent problems. The television picture is a good as it was when purchased new in 1996, however after some hours on we notice some horizonals lines across the screen. After a while the lines come more frequently then the picture goes out. I opened up the back cabinet, blew out the dust, and looked for any leaky capacitors. The only one that appears a little funky is c953. It doesnt appear like a regular capacitor. After reading around the net it suggests looking for cold solder joints around the power supply and points to resoldering the vertical IC chip. Does anyone have the part number and location of this IC? Any other suggestions? I am awaiting the download for the service manual, so I should have it shortly.
When the television plays, it works perfectly until the problem starts.
Thank you
  • jerry0001 Feb 24, 2009
    my blue is out of wack can anyone help
  • Yegg57 Apr 22, 2009
    Does anyone have any schematics of this unit?
    I think that there are 3 flybacks for the 3 crts, would they all fail simultaneously?
Can i get a manual for this tv, the blue is out of alighnment
Posted on Feb 24, 2009
  • 4,234 Answers
I'll take a guess here that the lines are at a slight angle. I believe that these are "retrace" lines and are an indication that the flyback transformer is starting to fail. The vertical IC would cause a collapse of the picture and bad caps in the circuit would effect the linearity of the picture. You can check for poor solder joints as they could cause any nunber of symptoms.
Keep us posted.
Dan
Posted on Jul 14, 2008
Dvd to vs 4544 hook up
Download the user manuals for both devices from net. You will get all wiring data from them.
May 29, 2012 | Mitsubishi Televison & Video
How do I hook up a dvd player to vs 4544?
Its a old set but hookup should from a DVD player be to the rear audio and video inputs---note color of jacks on player--you will need for that old set composite--yellow(video and color), red and white for sound.
If the player does not have them (composite) you have a real problem.
Once connected use the input button on the front of the set to change to that input that you hooked the player up to (video 1 or 2 etc.)
May 29, 2012 | Mitsubishi VS-4544 45" TV
Need Horiz button help on Mitsubishi 45" TV...easy fix?
No,require new main video backlight board,and vertical/horizontal stablelizer board also.Both boards alone cost u about $500 bucks not uncluding labors yet.
Oct 20, 2009 | Mitsubishi VS-4544 45" TV
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi vs-5041 picture intermittently goes off
my guess is convergance ic but to troubleshoot it the best soultion might be to get a can of freeze and spay it on the IC while the problem is happening and or tap the board/ic's to see if you have a loose connection,
Nov 29, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Have sound but no picture
solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Jul 07, 2007 | Mitsubishi VS-4544 45" TV
Black horizontal lines on mitsubishi VS-5043
Is the noise in all inputs (line, tumer) ? If it is in the tuner alone, check the coax lug to see if you knocked it loose. This could be the problem. Check you picture with a DVD player on the Video input. Let me know what you find.
Jul 03, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
193 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
