Question about Maytag Washing Machines
Matag neptune #MAH4000AWW Push start button, begins to fill and shuts off after about a minute, move to spin cycle, begins to drain and shuts off after about a minute
    Problem Solver:
  • 3 Answers
The repairs it called for was way over my head so I took it to a repairman today! Thanks anyway
Posted on Jul 15, 2008
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune MAH4000AWW will not finish a full cycle.
I had the same problem. I called customer support and they gave me these instructions:
Shut off the water supply to the machine, disconnect the hoses from the back of the machine. Pull out the hose and pull out the little screens and clean them with water or soak in vinegar. I was skeptical but did this and the results were amazing. Apparently if the screens get even a little "gunked" up (my screens really didn't look that bad) the machine senses the change in water pressure coming in and shuts it off. Hope this helps!
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer Maytag Neptune
Most likely the motor control unit, the MCU controls the timer (loop circuit). Best way to check is to just pull the MCU out and visually inspect it for burned components, although it is not always visible. You may need to make some involved voltage readings to verify.
Sep 22, 2008 | Washing Machines
Maytag Neptune washer model #MAH4000AWW, Press start botton starts filling then shuts off after a few seconds. Move to spin it begins draining then shuts off after a few seconds
Check out your motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
These kits are offered on the www.neptunewaxmotor.com order form and they ship UPS Ground.
This kit takes about an hour to install.
Don't forget to see the info on the website regarding the defective door latch wax motor that will eventually fail and damage your machine control board.
Jul 14, 2008 | Washing Machines
I press the start button, it starts to fill then shuts off after a few seconds. If I go to drain cycle, I press the start button, it begins to drain the shuts off after a few seconds. No noises or...
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness. This kit takes about an hour to install. See www.neptunewaxmotor.com for step by step pictures on how to disassemble your Neptune.
Jul 03, 2008 | Maytag Washing Machines
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
165 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
