Question about Maytag Atlantis MDE7400AY Electric Dryer
Will not come on
The dryer all the sudden dose not come on the light for damp ect works
will not come on
  • falconcrew2 Jul 24, 2008
    dryer won,t start,get a buzzing sound from on/off knob.drum rotates freely
  • 943 Answers
Hi thanks for the question i would check the thermal fuse located in the front of the dryer remove the front panel , and the thermal fuse is located on the air duct thanks the appliance doc
Posted on Sep 18, 2008
Control Panel Doesnt Light. Breaker is good. Interior bottom light works ?
possible bad connection to the cord, inside the dryer.. unplug it, remove the rear panel, and do a continuity check with a meter.
Mar 11, 2014 | Maytag Neptune MCE8000AY Electric Dryer
Air compressor
Recharge your AC unit with r134a , can be bought at a variety of places.. Autozone, O'reileys, napa, home depot.. ect...ect. Hope this works for you! good luck
May 18, 2013 | 1999 Chevrolet Venture
Aspire 5610, daughter cleaned with damp cloth, monitor does not work, lights up, no graphics
That should not have happened. However, I have heard that the following solution works for cell phones dropped in water where they open it up and use a hair dryer to dry it up. Try running the hair dryer on low around the edges of the screen but not so close as to heat it up. The wiping with a damp cloth does not normally cause this, but if that is what it is then the hair dryer solution MAY work. Good luck on fixing it without having to send it in for expensive servicing.
Jan 20, 2010 | Acer Aspire 5610-4648 Notebook
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
My Whirlpool dryer suddenly leaves clothes damp
Be sure to check the thermostats...they can cause this problem
Sep 22, 2009 | Whirlpool Dryers
My daughtrs 2001 Chevy s10 has an itermitant starting problem.
quick way to tell... next time it won't crank and just clicks... hit it gently with a hammer as you have someone attempt to start it... if all of a sudden it cranks.... it's the starter... replace it before it quites completely.
Robert
Dec 18, 2008 | 2001 Chevrolet S-10
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
71 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
