Question about Sharper Image KX101 Hair Trimmer
Changing Batteries I do not have the instruction manuel and I can't figure out how to remove and replace the batteries. Can you help?
  • 4cwise Jul 26, 2008
    Thanks, That is the trick!
The bottom cap Rotates about 45 degrees counterclockwise, then you can pull it off.
I replaced the batteries on mine but it still won't go unless I nearly pull out the blades. Too tired, I guess, after 3 years running.
Posted on Jul 26, 2008
How do I change out the batteries in a Safety First nodaway?
The battery compartment is secured to the bottom of the bassinet. Remove the baskets from the fabric shelf (if present) and look between the frame rails. The battery compartment has two covers, each secured by a Philips screws (one on each side of the compartment). Unscrew the screws and you'll see 2 AA batteries in each section. Match the orientation of the batteries when you replace them. Then replace the covers and their screws. Then put back the baskets.
The instructions for the Nod-A-Way Bassinet are available from the manufacturer: http://safety1st.djgusa.com/en/djgusa/nod-a-way-trade%3B-bassinet-bt044awu--1 . The direct link to the manual is http://safety1st.djgusa.com/product_instructions/en/BT044_inst_ES_030612.pdf .
I hope this helps.
Oct 11, 2014 | Safety 1st Baby Care
Alarm
that means your batteries are not charged fully. I'm assuming you have new fresh batteries? Does the panel stay up long enough to show the charge level?
Feb 16, 2008 | Samsung Digimax S630 Digital Camera
Hello I lost the Manuel for this Product and my wife took the batteries out and forgot to replace them but when I replced the Batteries the code to control the DVD was Lost can you help?
You can download the component code numbers document by clicking the link below:
Component Code Numbers
You can also download the operating instructions manual by clicking the link below:
Operating Instructions
Aug 24, 2011 | Sony RMV310A Remote Control
How do I change the battery in a logitech wireless battery. I can't seem to figure out how to open it to even see what kind of battery is needed.
For changing the batteries of logitech wireless.I guess a video tutorial will help you out rather than written instructions. Watch it to lean how to replace battery of the logitech cordless mouse ( Logitech MX 1000 Model). If you are having a different model please specify the details of your model.
Mar 02, 2011 | Logitech Cordless Mouse
How to solve the problam of lens obtructed?
install a new or fully charged battery/batteries into the camera.
If the camera was dropped this fix will not help you.Otherwise try changing the batteries
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Kodak EASYSHARE M1063 Digital Camera
Doll is new has not worked right since it was boughten. Before changing batteries mouth and eyes worked. and after changing batteries only mouth moves. what could be wrong ?
Amazing allysen takes two sets of batteries. When you open up her back you will see where you replace 4 AA batteries. If you open up the littel doors UNDER the AA's there is a space for 3 AAA's. That might be a solution.
Dec 05, 2010 | NRS Amazing Allysen Doll
Directions for changing battery
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws from back case.
3. Remove back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
6. Replace back case, and then replace screws.
7. Press: [OFF] [ON] [ON].
Caution: Dispose of old batteries properly. Do not incinerate batteries or leave where a child can find them.
Your calculator cannot hold data in memory when batteries are removed or become discharged.
Nov 27, 2010 | Texas Instruments TI-30XA Calculator
We have a mongoose 74 we need a battery charger
no battery charger needed. 2 AA batteries in remote, 4 more AA batteries in rear wheel. See instructions for changing batteries.
http://www.kidgalaxy.com/InstructionPDFs/big_wheelie_manual.pdf
Nov 06, 2010 | Kid Galaxy Big Wheelie Cylce Fun Rider
I need to know how to change the battery. Can you send a manuel.
Printed instructions for battery replacement are not provided by the manufacturer.
You will find batteries for model ES-1000 at shaveroutlet.com. See link below (you will need 2 batteries)
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
To open up the shaver, gently pry off the rubberized grip on the front with a small flat screwdriver or similar. This will reveal 2 screws at the bottom. Remove the screws and the flat plate under the cutters that clips on there. You can then gently pry apart the two halves.
You can then access the batteries, remove the old ones and solder the new ones in place
Oct 18, 2010 | Remington ES-1000 Electric Shaver
Car beeper
follow the instruction in our viper manuel you need to reprogram the system thanks pierre
Jul 30, 2008 | 2001 Mitsubishi Eclipse
Sharper Image KX101 Hair Trimmer Logo
262 people viewed this question
Top Sharper Image Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sharper Image Health and Beauty Expert? Answer questions, earn points and help others
