Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
Sea talk failure
I have Raymarine ST4000 Plus autopilot.
Sea talk failure has shown up on my screen. The auto pilot will not work.
Water depth screen works.
Boat speed works.
Wind speed does not work.
Doug
  • jhighsmith Jul 30, 2008
    ST 6000+ auto pilot displays "sea talk fail".....tri-data shows no display at all and my RL70CRC chart plotter indicates "no fix".....radar works fine.
    New Friend:
  • 132 Answers
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Posted on Jan 26, 2010
How can I put sea talk to a raymarine sl70crc plus to a raymarine 70crcl plus at the same time
I doubt you can because they will share the same power and you may cause issues if there is a short circuit anywhere. Talk to RayMarine.
Mar 06, 2017 | Raymarine Boating
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
Apr 06, 2010 | Raymarine St 4000 Wheel Drive E12093
Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
Dec 18, 2009 | Raymarine St 4000 Wheel Drive E12093
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Installing a Raymarine 8002/6001 on my 2005 Sea Ray 270
If you have a basic knowledge of electronics and can follow instructions. It's easy the hardest part is connecting the pump and bleeding the system.
Feb 19, 2009 | Raymarine St8002 Smartpilot Autopilot...
Auto pilot
difficult is it to install Raymarine 8002 autopilot in 270 Sea Ray
Jan 14, 2009 | Raymarine St8002 Smartpilot Autopilot...
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Raymarine gps sounder
This is a common problem if the GPS is hooked up to an electronic heading sensor such as an autopilot. If the heading sensor is not calibrated properly, the boat will appear to be facing the wrong direction.
If you have an autopilot, consult the installation guide and perform the sea trial procedures. That should get your boat lined up properly.
Jul 17, 2008 | Raymarine GPS
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
807 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
