Question about Kenmore Elite 45986 Front Load Washer
F02 How to fix the drainage problem
  • jesse643 Feb 11, 2009
    IT DOESN'T RINSE AND ON THE DISPLAY ITS AN F 02. WHAT CAN I DO TO FIX IT?
  • Anonymous Feb 17, 2009
    Code F 02
    I am having the same problem, for the second time in three years. Last time a technition came out, and took the front of the washer apart, found a baby sock in the drain. Looking for instructions to do it myself.
Question is answered if you search kenmore f 02
Posted on Jul 17, 2008
He4t error sud and f2
Hi, "F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean.
The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Jun 16, 2011 | Kenmore Elite 45986 Front Load Washer
Our Kenmore HE4T frontload washer is displaying an F02 troubleshooting code. What does that mean?
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
I am continuously getting a F02 error code which stops the wash cycle. When I hit pause and restart it does but then it errors again.
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Dec 05, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
110.42926200 HE3T, F02 Error
"F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Nov 26, 2009 | Kenmore Elite 45986 Front Load Washer
My whirlpool front loader washer is about 7 years old and when I run it, it beeps and flashes F02. What does this mean and how do I fix it?
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means there is a clog in the drain pump and it needs to be cleaned. The following link explains:
Nov 06, 2009 | Kenmore Elite 45986 Front Load Washer
My washer is display F02. what does that mean?
"F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Nov 05, 2009 | Kenmore Elite 45986 Front Load Washer
Showed F02. Doesn't spin in the spin cycle, just
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means there is a clog in the drain pump. If the drain system is clogged or restricted, once the error code is generated, the washer will not complete a cycle until the error is resolved. The following link explains:
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer beeps and displays f02
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means you have a clog in the drain pump. The following link explains:
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting error message f 02 which is a drainage problem but there is no drainage problem??????
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4THUMBS rating is appreciated for answering your FREE question.
Sep 23, 2009 | Whirlpool Washing Machines
My washer flashes a 02 error during the final spin/drain cycle.
f02 is a fault indicating poor drainage, try removing hte front access panel and cleaning out the pump housing!
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
512 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
