Question about Whirlpool Washing Machines
Whirlpool duet steam washer is displaying F28
Master_Tech
  • 770 Answers
SOURCE: whirlpool duet washer
F11=Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit
(MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control
Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
F28= No such Code could be out of the fact you have a F11
Posted on Feb 18, 2008
Krazytech
  • 725 Answers
SOURCE: New Whirlpool Duet Washer(WFW9300VU02) F28 error
You can call whirlpool for service but the tech sheet f28 has a communication problem from you computer to the motor..
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
Check connections of the CCU board within the housing.
Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Posted on Sep 21, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 220 Answers
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on Sep 13, 2009
  • 63 Answers
SOURCE: whirlpool duet f28 code
Turn off the power. Remove the detergent tray. Reach in the slot where the detergent tray fits and look for a lever. Pull it and replace the detergent tray. Turn power on. Good luck.
Posted on Oct 28, 2009
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam front loading
go to this link ........... it will show you step by step solution
http://www.ehow.com/how_8052747_fix-f28-code-whirlpool-duet.html
May 06, 2013 | Washing Machines
F28 code on a whirlpool duet sport model # wfw8300sw03
There is also a safety switch on the bottom compartment, if the cover is off it will display F28.
Aug 11, 2012 | Kenmore HE2 Plus Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
