My Toshiba 27A62 Tv keeps clicking on and off, but the set won't turn on it just keeps clicking on and off. Help!?
I have a Toshiba 27A62 TV that had the same problem. I changed the C531, 470uf 25V 85 deg was bad. I replaced it and the TV has been working for two weeks now. It even improved the picture.
Posted on Feb 04, 2012
When working with my Toshiba 27A62 TV with the same problem, we found that if we replaced the capacitor C520 on the main board it fixed that problem. It was a 25V 470uF cap located in the middle more towards the front 3rd of the board.
Posted on Aug 20, 2008
Model 20AK42 Toshiba won't turn on
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Televison & Video
S-video
if your laptop has s-video out then just plug it in to the tv's s-video input , otherwise its a RCA jack for the video ouput( yellow colored jack )
Oct 09, 2008 | Toshiba 27A62 27" TV
Toshiba 27A62 will not turn on
Good day.
please check on the supply to the horizontal output transistor. your flyback is not osscilating.
Response is highly appreciated.
chris
Mar 18, 2008 | Toshiba 27A62 27" TV
TV won't power ON
This problem will need to be repaired , it is most likely the EPROM chip or controling circuts
Oct 28, 2007 | Toshiba 27A62 27" TV
Toshia CT-90157 remote is not working!
Here is the product information for your remote: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C What is the correct model# for your set?
Sep 22, 2007 | Toshiba CT-90157 Remote Control
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Toshiba ct-90157
What is the model# you own, for your TV along with yout satellite system box? MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Toshiba 27A62
I do not know, but several people have said that Toshiba TVs make a clicking noise on switch on, this could be a relay, and not arcing. A power up circuit operates the relay. So two things could be going wrong. 1) The power up circuit input voltage is too low or weak to fully operate the relay, so the contacts do not close. Probably a faulty electrolytic capacitor. 2) The relay has bad contacts. Relays have become so miniature that you will probably find it is only slightly larger than an integrated circuit, and soldered on the circuit board. The long rest may allow a bad connection to oxidise due to dampness, and so conduct more, or allow a capacitor to recover some lost capacitance. If you know these parts of the circuit, you need a normal digital meter and a capacitance meter.
Oct 21, 2006 | Toshiba 27A62 27" TV
TV won't turn on immediately
Right now it should not be expensive to repair,the symptoms point to loose solder conection and it has gradually become worst,if you take the set to the shop it should cost less.What happens is the 10 legs the vertical ic has get overheated and loose,to prove this tap on the side of the set just to see if it reacts,it should also be check for other overheated areas while in service.If the quality of the picture is good then is worh repairing.
Sep 30, 2006 | Toshiba 27A62 27" TV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
