Question about Canon PIXMA MP160 All-In-One InkJet Printer
Mp160 the rubberband behind the ink got loose and its making a loud nouise please please help how do i fix it i already try putting the rubberband back but the noise doesnt go away
  • Canon Master
  • 5,568 Answers
Before you try this, put a couple of drops of resin-free oil such as 3 In One (sewing machine oil) or a tiny bit of penetrating lube on the shiny rod on which the carriage rides.
The original lube may have either dried out or has turned into a paste-lube gunk that is making the carriage hard to move.
If the 'rubber band' has teeth on the inside, it is the printhead drive belt and it may be stripped.
If the printhead centers for cartridge changes when opening a cover, let it center, pull the power cord out of the wall and carefully attempt to move the carriage by hand.
If you hear a similar noise, then the belt is stripped and will have to be replaced.
I'm not familiar with your model so can't advise if this is a do-it-yourself job or not.
Posted on Jul 14, 2008
Flash won't pop up all the way open.
What has happened is a tiny little spring has broken inside or gotten out of position. Rather than try to fix that, get a thin rubberband (with circular, not flat, cross section) of the proper length as determined as follows. When you turn on the camera, select "force flash", and then half-press the shutter button, you'll be able to lift the flash unit with a fingernail under the crack separating it from the rest of the camera. Once open, put your thin rubberband under the black plastic "ridge" at the front of the flash unit; this ridge is just above the glass-enclased flash tube. As you pull the thin rubberband toward the back of the camera, put a half-rotation into it so that the rubberband crosses over it self (makes an X ) halfway back. One of the X-loops is under the ridge. Put the other X-loop around and under the eyeball-viewing protrusion on the back of the camera. If the rubberband is short enough (but not too short), it will have enough stretchy force to hold the flash unit in the fully open ("up") position. If you're lucky, it may also pop it open when the flash is called for. If not, use your fingernail and just let the thin rubberband hold it in the up position. It works for me.
Feb 24, 2011 | Fuji FinePix S700 Digital Camera
My canon MP160 error 27. I've tried the trick in service mode.. But still can't reset it.. please help me..
E27 is the WASTE INK ABSORBER FULL error message. Try send it to service centre to do the WASTE INK ABSORBER replacementjob & waste ink counter reset job.
May 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My roller dont take in the paper
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
Error message: Service error 5100 on my new Canon MP160 Printer
no prob try -- As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Mar 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printers Problem Canon MP 145 code E27
Try this fix.....CLICK HERE
It works the same for the Canon MP 150 or MP 160
Jan 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 Error
Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Problem after replacing both ink cartridges on MP160
i want to use just scaner from my cannon pixma MP160, but i don't have catridge or the catridge was broken. can every one resolve may problem?
Jul 27, 2008 | Canon PIXMA MP160 All-In-One Printer
Ink moving very fast
Take a peak inside the printer where the ink Cartridge is and see if you notice anything out of place usually it has thin long plastic strip found behind the ink carriage unit make sure its there if its not there then u need to put it back into position you gonna need to take the printer two side cover off to do this
May 10, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon mp160 prints not alligned and dirty
put in canon ink, possible stuffed head if been using non oem ink
Jan 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
105 people viewed this question
old marine
old marine
