Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool refrig ED22DQ
Top light on refrig side doesnt work, even after new bulb. Others work, but come on only after short delay after opening door.
  • 126 Answers
THERE IS A NEED TO CALL A TECH IT MIGHT BE A WIRING PROBLEM.MOHAMED
Posted on Sep 17, 2008
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold gs5shaxnl side by side-the ref. side has no power and when the door is opened there is a clicking sound until the door is shut -temp is 33 degrees-everything is working on the freezer side...
replace the control board Part#4334000 appliance parts pros $80.25 if you recently blown a light bulb in the refrige section this will also ruin the board
Oct 11, 2009 | Whirlpool Refrigerators
Bulb went uot new bulb not working
...will need to check power at socket. using a multimeter.
Jun 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Light won't work even tho changed bulb whirlpool fridge
Have you checked the door switch, might be stuck in or defective.
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
Whirlpool Refridgerator Problem
you didnt include the model, but i would assume that the "control panel lights " are also out??, and a clicking noise when the refrig door is opened??? if so you have a bad electronic control board. its located behind the refrig on the left hand side munted inside a little white box next to the compressor,
Oct 26, 2008 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
191 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
