Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Not dispensing any liquid
We checked both belts. Spray works in hose attachment but not on upright machine. Both containers are full and they seem to be seating properly. Suggestions?
  • cnmhoward Sep 08, 2008
    Floor unit, brushes are spinning, no liquid dispensing. It was working until a loose piece of rug got caught in the brushes for a second. The upholstery tool works fine.
You will need to replace the proheat pump Key 41. Repair man says VAMUUM VERY good first once repaired. The hair will break the wheel that turns the wheel with a belt. It cost about $100.00 to take it in $23.99 if you buy it at www.vacuum24x7.com
Posted on Aug 10, 2008
No water when i start the machine
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
When button is pressed, water does not come out of the holding canister. still seems to have suction, but water doesn't come out to rinse/clean carpet.
Please check the following with liquid in both tanks.
Nov 22, 2010 | Bissell 9200 Upright Vacuum
My bissell has lost its prime, how to I prime it
Check the following with liquid in both tanks.
Nov 16, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x not spraying water
Nov 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The machine is not spraying water or cleaning fluid out bissell pro heat 2
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell Proheat 2x cleaner which has worked perfectly on every occasion. Today I filled the machine as usual with water and formula and switched on, the motor ran, the lights were on and the...
If these suggestions do not resolve the issue contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Bissell will spray water when set to water rinse, but as soon as it is set to light, normal, or heavy cleaning, there is no spray. I have tried priming but to no avail. I put plain water in the solution...
If these suggestions do not resolve your issue, contact BISSELL Consumer Services.
1-800-237-7691
Sat: 9am to 8pm ET
The Bissell is not dispensing water or cleaning solution.... The silver & black spinner does not spin
Check the following with liquid in both tanks.<br /> <br /> - Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.<br /> - <b>Check for debris on spray tips</b>. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access. <br /> - Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE. <br />- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.<br /> - Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.<br /> <br /> If the machine continues to not spray, check the following:<br /> <br /> <b>REMOVE THE COLLECTION TANK</b>:<br />&bull; Make sure the unit is set to water rinse<br />&bull; Remove the smart mix bottle and fill it with water only<br />&bull; Place the smart mix bottle into the collection tank reservoir<br />&bull; Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.<br /> <br /> If your machine continues to not spray, contact BISSELL Consumer Service at <a href="http://www.bissell.com">www.bissell.com</a>
Aug 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
We cannot get the water and soap to dispense in out Bissell steamcleaner
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissellproheat2x not sucktioning
If your machine continues to not spray, Contact BISSELL consumerservices at www.bissell.com.
Nov 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
43 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
