Question about Singer 7462 Mechanical Sewing Machine
How do you thread a singer merritt 4530 sewing machine
  • 323 Answers
All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Jul 14, 2008
I need a manuel for a Singer Merritt 4530 sewing machine
Most Singer sewing machine manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the Merritt 4530 is http://www.singerco.com/uploads/download/437_5_6_8_10_slide.pdf . Note: this manual applies to several machines with different available stitches.
I hope this helps.
Sep 01, 2017 | Singer Sewing Machines
Where would I oil a singer Merritt 4530 model machine
Singer has the manual for the Merritt 4530 on their manuals site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/437_5_6_8_10_slide.pdf . See page 44 for the picture of the points were you should apply sewing machine oil. You'll need to oil 8 points under the face plate on the left side of the machine. Most are places on the needle bar shaft. There are a few connected to the thread take up lever. If you move the hand wheel, you will see most of the points that need lubrication.
I hope this helps.
(In this case, the picture is much clearer than any verbal description I could give.)
Sep 21, 2016 | Singer Sewing Machines
Does the Singer Merritt 4530 uses the same footpedal as the 4530 c? My S Merritt 4530 c is 22 years old and I love it, but misplaced the footpedal after we moved.
Yes, the 4530C was only a variation to the 4530. It actually also fits a wide range of models, including some manufactured by Brother and J. C. Penney.
May 26, 2015 | Singer Sewing Machines
How to put the bobbin holder back in place in a singer merritt #4530
Download your user's manual free at the Singer Sewing Machine website; it's on page 41 with drawings.
Jun 09, 2014 | Singer Inspiration 4210 Mechanical Sewing...
How do i thread my bobbin on my singer merritt 4530
Run the thread around the little silver knob on the top of the machine to the bobbin threader on the top right. Wrap the thread clockwise around the bobbin a few times and then pull the bobbin threader toward the silver bar. If you put your hand on the crank wheel, you will feel a place for your finger to set. Push there and the center of the crank wheel will sideways allowing you to thread the bobbin when you press the pedal. I'm sure my terminology doesn't make any sense.
Jul 11, 2009 | Singer 7462 Mechanical Sewing Machine
Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
Adjust timing on Singer Merritt 4530
what size replacement needles for a singer merritt 4530
Oct 21, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
247 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
