Question about Maytag Dryers
Maytag pye2300ayw - drum will not turn - Maytag Dryers
    Scholar:
  • 148 Answers
  • probally have to replace the belt
Posted on Jul 14, 2008
  • derek martin Jul 14, 2008
    probally replace the belt
I have a loud noise coming from the bottom right side of my dryer. I am trying to figure out how to open the cabinet up to see what the actual problem is but I can not tell how to open it. There seems to...
maybe the drum rollers,Tim:
http://www.partselect.com/dryer+maytag-atlantis-drum-removal+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
May 29, 2011 | Maytag PYE2300AY Electric Dryer
Belt installation is too loose on Maytag dryer model # pye2300ayw? Trying to fix it need a diagram??
Hi and welcome to FixYa, I am Kelly.
If the belt is loose it is most likely stretched / worn and should be replaced:
The idler (item5) of this drawing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=630165#d630165
See routing here: http://www.repair-help.com/kb/index.php?article=105
The drive belt is item 5 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=695560#d695560
The top must be opened and the front panel removed to install the belt.
Here is a link to step by step "how to" instructions.
http://www.ehow.co.uk/how_7277908_do-belt-maytag-pye2300ayw-dryer_.html
Make sure to inspect the rear drum rollers while you have the dryer open. Item 7 this link:
Flat drum rollers or hard to turn rollers will cause the new belt to fail prematurely.
Additionally if the front or rear drum seals are worn it can cause the belt to be loose. These are glued on with high temp adhesive.
The front seal is item 10 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505910#d28505910
The rear seal is item 2 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505913#d28505913
High temp adhesive: http://www.appliancepartspros.com/part_details.aspx?part_id=4284239
By replacing the items above your dryer will operate like new again and extend the life of your dryer by many years.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Maytag Dryers
The barrel doesn't turn
This dryer is belt driven. You did not mention if the motor was running or not but, I am going to assume that the motor is in fact running and the drum is not turning. There is not a belt safety switch on this dryer so if the belt breaks the motor will run but the drum will not turn.
Make sure to inspect the rear drum rollers wile you have the dryer open. Item 7 this link:
Kelly
Mar 27, 2011 | Maytag PYE2300AY Electric Dryer
How do I replace the dryer belt on a maytag dryer model #pye2300ayw. How do you connect to the pulley and get the belt around the drum?
lift the hood by pushing in clip on either side. remove two screw at top inside to remove front. unplug first. thats as far as we go there. remove belt out of dryer. take new belt and put on drum groove side down, get it uniform around drum. putting belt on pulley might be easier to do from behind for you. two screws to remove small access panel.take belt under pulley and over and around motor pulley. turn drum slowiy to make sure belt is not twisted. this belt can only go on a couple ways and one is obviously wrong. good luck.
Jan 30, 2010 | Maytag Dryers
Maytag pye2300ayw hums when you push in to start, sometimes will get started but not always
Sounds like the motor is weak and needs replaced. Or something is binding the drum and not letting it turn freely.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer model#PYE2300AYW turns on but makes loud noise when tumbling. whats wrong with it?
If it is a metallic noise, it can either be a pulley with bad bearings, or possibly the rear drum support/ bearing. If squeeling noise, possile belt. I would open the unit and check it out. Keep in mind that, in many cases, the repair can be more than buying a new unit. I bought a good, new dryer from Lowes for around $200. It would be hard to get a repair guy to come out and do the repair for that amount. Choose wisely grasshopper.
May 08, 2009 | Maytag PYE2300AY Electric Dryer
PYE2300AYW Dryer how do you remove the drum?
Once you loosen the screws from the spindle or axle, you should be able to pull(gently) the drum out. Be careful not to damage the rubber wheels. My question is why do you need to pull the drum anyway? It has nothing mechanical or electrical to it. Are you wanting to put a belt on?
Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
I have a maytag model # pye2300ayw while in the middle of drying a load a clothes it just quit i turned it back on now the timer is the only thing clicking nothing else is happening
Check your breaker, then the wiring in the back. It sounds like it could be your thermal overload switch is bad. Does the drum turn on even though it may not have heat? This will help me analyze it.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Where in Thermal fuse located maytag model #PYE2300AYW
Take the top off the dryer and you should find it located at or near the drum.
Jan 17, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
345 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
