Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
How to replace pull cord on Cub Cadet lawnmower
  • Anonymous Aug 16, 2008
    Exactly the same problem. The pull cord simply broke, and I've got to figure that this is an easy fix to do myself rather than leaving it with a repair shop for 2-3 weeks.
  • Anonymous Sep 20, 2008
    my pull cord broke when i removed the cover to fix. there seem to be no place to run cord
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Cub Cadet 1525 belt diagram
Attached is the blade diagram for correct placement of the deck belt. There is some bleed through from the back page, but you can see the direction of the belt. I have a 1525 mower for the last 11 years, still running and going. Hope this helps! 25105582-ergctme4kokczpvvmmku3zkh-5-1.jpg
Sep 15, 2014 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
Broken Cub Cadet
I dont own one or there but it is an easy repair. Find a wrench/socket that will fit the 3 or 4 bolts holding down the pull cord (recoil) cover and remove them and the cover. (Prob. a 10 mm socket) Then wrap a cord/narrow rope CLOCKWISE around the pulley 3-5 times and prepare mower to start as you normally would and pull the rope. Now you can cut your grass before it becomes unmanageable. Take the recoil to any small engine repair shop and have them replace the rope and then you can reinstall the recoil. In my area the charge $7-$10 for this.
May 20, 2013 | Garden
Timeing pull cord rip out of hand when trying to start mower model 18m
what you have done is sheared the flywheel pin top of eng pull fly wheel you will find a schered pin go to lawnmower shop possible with pin get replacement just a few dollars you be back in timing and back to work let me know if you need a walk thru sparks
Apr 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
205 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
