Question about JVC Everio GZ-MG27 Camcorder
Temp warning I'm reasonably confident that there is a temperature sensor, otherwise how would it know? The parts website just covers accessories like batteries, tripods, and cases and such. Nothing about internal circuitry. It's no longer covered under warranty, otherwise it would be easy. I tried the reset thing before, and it doesn't do anything. That's kinda how my luck runs. But, thanks for trying. I appreciate the effort.
  • JVC Master
  • 13,433 Answers
Can you hold on for a few hour and up to a day? il contact jvc directly - I really don't know if it has a temp sensor. Didn't see it on the parts list. Il get back to you with 1-2 days with the details.
depends on how fast they repond.
Posted on Jul 14, 2008
  • Ekse Jul 14, 2008
    email sent
  • Ekse Jul 16, 2008
    JVC support:
    Since we are not certified as technicians to diagnose product problems, our best advice is to refer you to an authorized service center for proper evaluation or possible repair. The following link will direct you to your nearest factory service center (FSC) as well as offer answers to commonly-asked questions about our Service policy:
    FSC: http://support.jvc.com/consumer/support/...
How do i change the air temperature sensor on a 01 mercury sable
Air Temp Sensor should be included
inside the MAF Sensor--- isn't it?
No reason that should be bad
Has it been tested or scan tool data looked at?
You don't change parts on a guess, for no reason
Any codes you may have,got nothing to do with
changing parts
Nov 28, 2014 | 2001 Mercury Sable
Which fuse is for temperature gauge on dashboard
  • The temperature gauge is not on a fuse of its own, it would work with all the instruments, ie fuel gauge, warning lights etc. If the temp gauge does not work and the fuel gauge does,, look for the problem elsewhere such as the sender unit on the engine. A quick check is to remove the wire from the sensor unit on the engine and short it out to ground. If the gauge picks up, replace the sensor unit.
  • Otherwise, check the wire itself for breaks, or bad connections.
Sep 27, 2014 | Cars & Trucks
2007 ford focus 2.0 litre
That is ok because all it is doing is telling you the temp of the transmission oil
Apr 22, 2013 | Vehicle Parts & Accessories
Temperature and oil pressure gauges not working
check the sensors .take off the wires one at a time clean them check for breakes in the wiring.
Jan 02, 2013 | Gauges for Ford E250
Is the coolant temperature switch the same as the coolant temp sensor?
There should be two parts - a switch that turns on the Hot warning light or a sensor that works the temp gauge on the dash, and a second sensor for the computer.
Jul 02, 2012 | 1997 Chevrolet Cavalier
Where is the temperature sending unit located on a 2000 chevy s10 2.2 four cylinder engine
The temperature sending unit is screwed into cylinder head. Careful you also have a coolant temperature sensor that threads into intake manifold. Temp sending unit is how your guage knows how hot your engine is. Coolant temp sensor is how your computer knows how hot or cold your engine is, so it can compensate fuel & air mixture.You can not put the wrong one in the wrong place, they will not fit. You change 1 for 1 reason & the other for another reason.
Jun 16, 2010 | 2000 Chevrolet S-10
There are two sensors connected to the thermostat housing and i need to know which sensor is which and what they control. on cold days i cant get started
The larger of the two is the coolant temperature sensor. The other is the actual gauge temperature sensor. The coolant temp. sensor gives information to the cars computor & when the car reaches a predetermined temperature, the computor changes the ignition timing allowing the car to run at normal operation temperature settings. The temperature sensor gives info to the dash board gauge &/or temp. warning light. The reason you can't start on cold days is that your coolant temp. sensor is stuck in advanced mode & the timing is to far advanced . To remedy this problem change the coolant sensor. Good luck!
Jan 04, 2010 | 2000 Ford Contour
The temperature gauge on my 2002 grand prix dose
the temperature sending unit on a 97 grand prix 3800 gt(which is also the coolant temperature sensor) is not accurate. the sending unit part of this sensor only sends info to the guage on the dash. the coolant sensor part sends info to the computer of the car. it is located under thermostat and somewhat difficult to get at. i had put a brand new one in and my temperature on my dash is all over the place---even with good thermostat and properly bled system. when i hook up a scanner to my computer, the coolant sensor is sending the computer(ecu??) what seems to be the right temp. anywhere from 194 degrees to 217 when hot. the guage however on dash go from 160 to 260 in less than 2 minutes.
Nov 16, 2009 | 2002 Pontiac Grand Prix
Where is the ambient temp sensor located on a 2001 S40 Volvo?
Go to Matthew's Volvo Site and search under "ambient temp sensor" I posted detailed instructions and pictures of how to fix this. Enjoy
Apr 16, 2009 | 2001 Volvo S40
Over heating
In general I know of no reason per se to replace the thermostat and temp sensor because you replaced the radiator fan. If the temp gauge seems to be staying in the 1/3-2/3 of full scale, and there is no apparent engine control issues as the engine warms from cold to operating temperature then there is no obvious reason to replace those items. Other than fan motor failure is there any reason for you to believe these other parts are at fault?You can get a free fault code readout at an Autozone parts store which would highlight a temp sensor problem, but there is no fault code for the thermostat except maybe the one for engine running cold for too long a time after start up. You could also check the resistance of the temp sensor which should run around 10-14,000 ohms when cold and drop to 700-1,000 ohms when warmed up.
I don't know about the issue of replacing the thermostat because I don't know which engine you are working with. So let me know an
Jul 12, 2008 | 2002 Chrysler PT Cruiser
JVC Everio GZ-MG27 Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
