Question about Amana Washing Machines
Amana washer model# LW8203L2 leaks from bottom when spinning.
The water is splashing over the top of the tub... i gonna replace the anchor springs that are supposed to hold the tub in place but also act as a shock absorber . Think the springs are shot!
Posted on May 16, 2009
    Scholar:
  • 148 Answers
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Jul 14, 2008
I have an Amana 2002 top loader washer model AlW880QAW.
take the front panel off. some of them have 2 screws at the bottom left and right side. Some of them you need to take a putty kinife and run across the lid and the front panel and find the clips there are two. push in and lift the lid. then remove I believe it's a 5/16 bolt to remove the front panel. You will then be able to see where the leak is comeing from. It could be just as simple as a hose or pump. But if it is leaking where the transmission meets the tub then that will be major surgury for someone who has never done that before. Does it sound really loud while it is spinning like a train is in your house? please let me know what you find and if you need any other help
Jun 02, 2009 | Amana ALW880WH Top Load Washer
Amana ALW880QAC is leaking at bottom of tub
that is a pricey repair.not an easy repair.your best bet is to buy a new machine.
Mar 09, 2009 | Amana ALW880WH Top Load Washer
Washer spins during agitate cycle
Most of the time IF a washer agitates and spins at the same time, the transmission has failed.
Good Luck!
Feb 20, 2009 | Washing Machines
Amana washer
take the front panel off, two screws at the bottom of the front panel, probably a 5/16 nut driver will work. You will need a flash light. partially fill the washer with water and then turn it to spin.
Look up underneath the tub and see where the water is leaking from. If its coming from above the bearing you need a seal job.
Bearing, seal kit, not cheap, how old is the machine, time to buy a new one?
T
May 12, 2008 | Washing Machines
Replace mixing valve
There are usually 2 screws on the front of the machine just above the lower access panel, but on the bottom of the front panel which need to be removed before the entire top of the machine will slide off of the front. Also be sure to access the control switch area to unplug the wiring harness before you move the top of the machine too far.
Dec 06, 2007 | Amana ALW480DA Top Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Washing Machines Logo
364 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
