Question about Panasonic PV-GS150 Mini DV Digital Camcorder
No power i charged batteriy and put on unit still no power. i plugged into ac adapter no power. is there anything i can do besides bring it to a repair shop.
  • mike j Jul 14, 2008
    i charged the batteries on the same ac adapter, so im pretty sure its working properly
  • Panasonic Master
  • 2,794 Answers
Only the repair shop will know why there isn't any power to you camera.
Have you tested the ac adaptor to see if it is still holding power?
If it isn't. Then it needs to be replaced.
Posted on Jul 14, 2008
  • Tim Babcock
    Tim Babcock Jul 14, 2008
    You could clean the batter contacts on the camera. That could get rid of oxidation and provide better contact for the batteries.
Where do I purchase an AC Adapter?
Radio Shack is a good place to get a new AC Adapter. Although you can find many used AC adapters at Goodwill stores, and some Pawn shops also carry a box of used AC adapters to sell. They usually have many, because when something doesn't work, they keep the electrical adapters and sell them. I would suggest,if your able, to bring the electrical device with you when shopping for the adapter. This way if you go into a Radio Shack they will know exactly what kind you need. If you go into a Goodwill store with your device to search through the used AC adapters. They also have electrical test plugs and you are able to see if the adapter works with your device. Be sure to put your item in a bag so that it doesn't look like your stealing something when you leave the store. I have done this several times and never had any problems. If anyone questions anything, you just tell them your searching for an adapter to fit. If it makes you more comfortable you can let someone know at a front desk that you have brought your own electrical device in to search for an AC plug. That way when you leave if anyone questions anything, you have someone to verify it. Just some suggestions..hope it helps.
Apr 03, 2014 | Computers & Internet
Tip
AC adapter connectors
<a>HP, Compaq, Toshiba a</a>nd some others have problems with their AC adapter connectors on the motherboard. This is because they are not secured to the motherboard very well. They are just soldered to the board by the adapter leads. This puts stress on the leads whenever the plug is bumped or from plugging and unplugging the adapter. The adapter connector will, over time, become loose. The adapter will then not charge the battery, and when the battery becomes weak, the system will not power on. Some times, the unit will power on, but will shut off if the adapter plug is wiggled. If you continue to operate your system in this state, heat will build up from arcing at the ac connector and will burn the motherboard. If not repaired, the system board and CPU could be damaged beyond repair. Replacing the motherboard is then the only option<span> This could cost $350 and up. So the word is </span><span>GET IT REPAIRED EARLY</span>
on Apr 25, 2011 | Computers & Internet
Rv510 plugged in but no lights on my laptop
You need to check all of these: 1. External charger, 2. Battery, 3. Internal charger, 4. Software. First, check if the battery is fully charge (or more than 80% charged). Second, use a tested good working battery charger/ac adapter to test your ac adapter (go to local electronic stores and test your laptop with their ac adapters). Third (if your ac adapter and your battery are good), then check your Power Options (click Help and search "power option" if you don't know where it is). If the Power Options is ok, then your motherboard (internal charger) has a problem. You need to bring your laptop to trusted local laptop repair shop.
Feb 28, 2014 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
My HP pavilion ze4949 will not charge the battery. I got this laptop 2nd hand, and the "charging" light that the manual states should be lit while the AC adapter is plugged in has never lit;...
Take the battery out and see if the A/C charger will run the PC.
If so the portion of the PC Motherboard that charges the battery has failed.
The Motherboard is the heart of the PC and quite difficult to replace at home.
Go to a PC repair and see if it is worth fixing. BIG Labor cast.
Sorry!
Aug 13, 2011 | HP Pavilion dv6000z Notebook
My laptop is not switching to AC mode even when plugged into Ac Power outlet. I work on battery mode and after full battery drain, the laptop goes into hybernation...once into hybernation it starts...
1. You may possibly have a faulty power supply adapter. Contact the manufacturer and see if there are any call backs on the power adapter for you laptop unit
2. you may also have a damaged connector at the laptop connection. This will require repair by a technician.
Aug 03, 2010 | Computers & Internet
My Garmin 765t won't power on. Anything I can do
Unfortunately, there is not a lot of easy user troubleshooting for Garmin units. I will note that the AC adapter that plugs in the USB port will give the unit more power than a USB connection to a computer or the 12vDC car adapter. If you've tried connecting it to the AC adapter and it still won't come on, it is possible the internal battery has gone bad and is consuming more power than the supply can produce to both charge and power up the unit. You can try leaving it plugged into the AC adapter for an hour or so and then trying to power it up with the AC adapter plugged in.
Let me know what you've done so far to troubleshoot and I'll research some more for you.
Feb 24, 2010 | Garmin nuvi 765T GPS Receiver
Dell latitude 810 will not power up and says low battery
if you plug in to charge your battery and its not charging replace the battery with a new one and a ac adaptor plug, just to avoid any more damage to your pc notebook, dont try to repair if you are unsure on what to do
Nov 23, 2009 | Dell Latitude D810 PC Notebook
VOSTRO 1710 BATTERY WON'T CHARGE
If the battery will not charge, try this:
1.) First, power reset the unit by powering it off, unplugging it from AC power, removing the battery, then push and hold the power button on the unit for about 60 seconds.
2.) Next, plug the AC adapter back in (LEAVE THE BATTERY OUT), power the unit on. Does the unit power on?
If yes, Power the unit off and put the battery back in, let it charge overnight. If, after this the battery will still not charge, you will have to replace the battery. Contact the OEM to ensure you get the correct battery.
If no, remove the AC adapter carefully, look inside the DC port (where the charger plugs in to the laptop) you should see a small silver pin. Is this pin missing or bent? If the pin seems to be in good shape, then most likely you will have to replace the AC adapter. If it IS bent or missing, then you will need to contact a laptop repair center.
Oct 08, 2009 | Dell Vostro 1500 Notebook
Ac adapter's wont charge battery or pwr. unit
I would say take to a good PC repair shop (Not Geek Squad) and ask them to look at the power jack on the motherboard, it may need replacing. Next would be more of a a motherboard problem and its just quit. Good repair shops could help you either way get it fixed. I don't recommend anyone tackling any sort of laptop motherboard fix unless you really know what your doing.
Apr 20, 2009 | Dell Latitude D510 Notebook
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
Panasonic PV-GS150 Mini DV Digital Camcorder Logo
133 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
