Question about Whirlpool LER4634J Electric Dryer
Whirlpool Dryer not heating
Hi there.  We have a Whirlpool LER4634J model dryer that now refuses to heat at all.  We've noticed over the past few weeks that sometimes it'll take two cycles to dry thoroughly, but today there's no heat at all coming from it.  We had a power outage last night for a few minutes.  Does that have anything to do with it?  We also have a Whirlpool Electric Dryer (LER4634EQ3) that's not heating. I noticed this about two weeks ago. We clean the lint tray after each use. Can you help me?
  • brandon909 Jul 16, 2008
    I just moved into a new place and had to change the 4 pronge plug to a 3 prong plug. I am not sure if I connected the new 3 prong pulg correctly to the dryer. The 1st time I connected the 3 prong to the dryer, and plugged in the plug to the wall, I got a big "spark" that came out of the wall and it would not turn on, so I found that I did not have the ground wire conneted to the correct spot. I change the ground connection and got power but, now I have no heat at all and I have ran it through 3 cylces. Can you tell me if I am doing something wrong or what I need to do to fix the heat??
  • Anonymous Aug 02, 2008
    dryer refuse to heat
My electricity went yesterday and the city came out and flipped a breaker outside and the all of the electricity came back on and then the Heat started working on the dryer. I GUESS IT'S FIXED NOW.
Thanks for all of your help!!
Posted on Jul 17, 2008
  • 481 Answers
First check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Posted on Jul 14, 2008
  • Mike Durland
    Mike Durland Jul 17, 2008
    to brandon909
    • if you already checked the breaker, then you might have damaged the outlet or the wiring in the house, so check the voltage at the outlet for a full 220v and across the neutral (from hot to neutral should read 110v on both sides)
    i doubt that the heating element was damaged.
Whirlpool dryer model LEW0050PQ doesn't heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Whirlpool LER4634J Electric Dryer
LER4634J Electric Dryer: dryer will not heat...
heatman101
[p]
May 17, 2010 | Whirlpool LER4634J Electric Dryer
Have a Whirlpool dryer 6 yrs, last few weeks noticed that the drying cycle took longer, today the dryer goes on, turns, but does not heats up. Can you help me? I'm desperate.
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 15, 2010 | Whirlpool LER4634J Electric Dryer
Dryer wont heat
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it iwll help you find tha thing that is causing your problem..
heatman101
Apr 06, 2010 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool dryer model #WDE5840SW0 and it is not heating. I replaced the heating element and it is still is not heating. Any suggestions??
Hi, before replacing a element, verify power was being delivered to it or just ohm it out. Sounds like a high temp limit or a defective thermostat.
Jan 21, 2010 | Whirlpool LER4634J Electric Dryer
If it was taking longer to heat it probably has a restricted vent. Check for lint build-up. May also have blower cage full of lint.
UNPLUG UNIT FIRST!!
To access blower cage, remove rear panel. Remove four screws holding duct on left side in place at bottom. Remove two screws at filter area on top. Pull duct out at bottom and reach inside and remove lint.
Also ohm out all thermos. Check thermos on side of heater. Check white one to right of duct you cleaned. Check between larger two wires on four wire thermo. All should show zero resistance.
Check between two outside blades of plug. Should have about 220 volts. Pull plug out slightly and carefully check for power between outside blades. Then check for 110 volts from center to either outside blade. It only requires one 11o volt circuit to run, but both to heat.
Nov 08, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 22, 2007 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
338 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
