Question about NComputing L230 Network Terminal
Ncomputing l230 cannot run on windows 2003 server 64 bit sp2
At present Ncomputing supports only 32 bit version softwares.
Posted on Jul 18, 2008
Problems in n computing L230 model not working in windows 7
Hi!
Please download and install the latest software for your operating system from here:
http://www.ncomputing.com/softwaredownload
Hope it helped.
Aug 27, 2011 | NComputing L230 Network Terminal
We are using L230 device and when we try to connect to the server the following error message pops up" terminal server is not at ready. please try a bit later". But when i use the same device to...
There were some issues with single core vs. multi-core processors with earlier versions of vSpace. Perhaps the two server/hosts you're using as a reference point are different in that one is single core, the other is multi-core. Regardless, my recommendation is to uninstall the vSpace software, reboot, run their cleanup utility, and reinstall the latest version. Before reinstalling, make SURE that you have applied any Service Packs and ALL of the current MS updates. Additionally, browse Device Manager and make sure there are NO missing or conflicting drivers. Do NOT, I repeat, do NOT install from the provided CD. As of this posting date, the cleanup utility is available here: nc-eng.com/tools/ncuninstall. The most up to date vSapce for L230 is on the NComputing download site. If you hit this post later and the supplied URLs are not valid call NComputing TS at 888-365-1210. Lastly do NOT forget to register the vSpace software.
Jun 23, 2011 | NComputing L230 Network Terminal
First l230 connect to vspace ok,then i installed safe360 , then l230 report "terminal server - yet not ready. please, retry ..."
What is Safe360, an AntiVirus or Firewall software? If so, the program may have inadvertently blocked port access to the kernel which vSpace needs access to for user sessions. Below are the port exceptions for firewall configurations and file exceptions for Antivirus configurations. Current as of this post.
  • Port Exceptions
    • For L-series device connection
      • TCP: 27605, 27615, 3581, 3597, 3645, 3646
      • UDP: 1027, 1283, 3581
    • For vSpace registration
      • TCP Port 3630
      • Point to:
        • register.ncomputing.com
        • or 85.214.107.229
    • For vSpace Update
      • TCP Ports 20 & 21
      • Point to:
        • 70.182.176.102
        • or 81.169.173.128
        • or 81.169.173.128
  • File Access Exceptions
    • For vSpace functionality
      • C:\Windows\system32\KMServc.exe
      • C:\Program Files\Common Files\NComputer\Bootsrv.exe
    • For vSpace tray icon
      • C:\Program Files\NComputing vSpace\KmMsg.exe
    • For vSpace Registration
      • C:\Program Files\NComputing vSpace\KmRegWiz.exe
    • For vSpace Update
      • C:\Program Files\NComputing vSpace\KmUpdate.exe
May 01, 2011 | NComputing L230 Network Terminal
Ncomputing server 2003 hang problem when user (L230) login to server
Make sure you're on the latest vSpace software for W2K3, that version is v4.9.5 and is available on their download site. The issue you mentioned will be resolved if you update your software and register it. Make sure to enable bakground hardware activation in the system settings. That's managed through the vSpace console.
Apr 25, 2011 | NComputing L230 Network Terminal
Terminal server - yet not ready, please, retry attempt a bit later, with L230 and vista 32 bits
Uninstall any current version of vSpace. Reboot. Makesure you have no missing or conflicting device drivers inside of devicemanager. Then run the NComputing cleanup utility located here:www.nc-eng.com/tools/ncuninstall.exe. Download current version for yourOS from the NComputing download site, install vSpace and reboot and register. Do NOT, I repeat, do NOT install from theprovided CD and upgrade. Simply install straight from the downloadfile I provided in the link. Lastly makeSURE you REGISTER vSpace. Be sure toenable the background hardware activation option. This is available on the last screen of theregistration or in the NComputing System console, under System Settings.
Mar 21, 2011 | NComputing L230 Network Terminal
Hi, when i try to connect thin client(L130/L230) , i get following error "ts error stations limit exceeded " , configuration is Dell power edge T110 , OS is Windows server 2003 , i have tried...
I need more details to help
How many TS licenses do you have?, are they PER SEAT or PER USER?
I suspect that you'r TS licensses are PER SEAT
seeya!
Dec 18, 2010 | NComputing L230 Network Terminal
I have config the ncomputing dell powerdege T110 systems. i have in installation and configuration win2003server sp2 when i configuration on dell T110 systems server my ncomputeing dives not connecting to...
Hi Jerod - we'd like to get some more info from you on your specific configuration to narrow this down. But, it's likely an issue specific to the T110 (quick way to isolate is to run 2003 Server in a VM on the same machine to see if you still have the issue). Please contact us at http://www.ncomputing.com/techsupport (online or phone support) and we can help you with this.
NComputing Tech Support
Nov 11, 2010 | NComputing L230 Network Terminal
L230 Network Terminal: terminal server yet not ready please retry attempt...
This problem appear after u updated windows. U must update vspace with vSpace_4.05.002.03_for_Windows_L-Series. Register required and free on ncomputing sites, download and try...Itried it and solved this problem
May 17, 2010 | NComputing L230 Network Terminal
I've got 3 L230 Terminals all ask for a password I never set.
try to add users with password on your windows 2003 server first and test and see if this resolve your issue you c
Jun 28, 2009 | NComputing L230 Network Terminal
NComputing L230 Network Terminal Logo
574 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
