Question about Amana ABB1921DE Bottom Freezer Refrigerator
What does knob at bottom of fridge(behind kick-plate) do?
When I turn this knob it clicks untill it turns off fridge fan. When I turn it again it turns the fan back on. Where shouls I set it. I do not see any markings on or around the knob?
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty service...Catriver...post back.
Posted on Jan 05, 2007
  • 1462 Answers
SOURCE: Bottom portion of fridge does
probably compressor starting to fail or blockage in sealed system. bad news
Posted on Aug 09, 2008
aborcass
  • 2651 Answers
SOURCE: Amana side by side red turn knob at the bottom what is it?
thats the defrost timer. its merely a clock thatcycles the refrig in and out ofdefrost cycles,shouldnt be set to any particular place, it will free turn just a s as clock will
Posted on Feb 03, 2009
  • 1218 Answers
SOURCE: We have a amana BX21VW bottom freezer
Good day,
There is no repair possible. You could try changing the blade only, but the best repair is replacing the motor and blade as a unit.
However, it is your choice on the blade only approach.
Posted on Feb 25, 2010
Fridge is freezing food fan seems to be running all the time
sounds like you may have a stuck freezer control.try bumping that knob with the back of your fist,if it stops,that is it.if not it still may be the problem.let cool down in freezer for 10 min. open freezer door and turn knob back to off very slow,if it kicks off just at off ,control most likley bad.
Apr 16, 2014 | Frigidaire Refrigerators
Freezer works, fridge does not. The coils in the freezer wear iced over. Unplugged, thawed, turned defrost timer switch til it clicked. Plugged back in. Freezer still getting cold. Assuming defrost timer...
The defrost timer for a model FRS26ZSG is found behind the kick plate at the bottom and front of your refrigerator. You will need to pull the kick plate off. If you turned the timer then that is the defrost timer part number=> 215846602 Defrost Timer I am here should you have questions, Sea Breeze
Jul 30, 2013 | Frigidaire FRS26ZSG
Amana ARS2365AC Refrig. Noise from under refrig. Refrig getting warmer inside. It clicks like a switch is trying to turn on them gives off a high pitch hum for about 30 seconds. I have made sure that it...
first thing to check is the timer,remove the bottom kick plate,on the left side you'll see a knob,if you can turn it by hand turn it slowly or use a screw driver and turn it until it clicks,it could be stuck in defrost,if the compressor runs then you need to change out the timer.if nothing happens turn the timer until it clicks again.now go in the rear of the machine,unplug the fridge,remove the bottom rear panel and you'll see the compressor,there's a start device on the compressor and they do fail.remove the clip and before you remove it look and see where it clips on to,so when you have to put it back on or replace the part you know where to clip it again.slide off the start device,shake it,if you hear a rattling noise like a piece is broke off inside it or if it smells burnt this is your problem,the part number is W10189190 and it's like 20 dollars.when you call your parts store,give them the model number off the fridge and give them the p number and they will make sure the part number i gave you is correct.now from what you are discribing it sounds like the compressor isn't running,is this correct?and the machine is getting warm.when you change out the start device and if the compressor still doesn't start then you have a bad compressor and most likely you'll need to change out the machine.let me know what you find
Mar 20, 2011 | Amana Refrigerators
Auto defrost is broken
Find the defrost timer and turn it with a screw driver (will only go clockwise) until it clicks.n wait 10-15 min. If the defrost starts to work (Freezer will get warmer heaters kick on) the timer is bad. If not you will need to check the deforst heater (behind back panel of freezer) and thermostat (silver cylinder with 2 wires on the evap coil) The timer is eithr under the box behind the kick plate (clean the coil while you are there) inside the refrigerator (look in the top for a small hole with a funny knob) or back behind the frig near the compressor( clean here as well).
If it goes into defrost and defrosts, rotate the timer until it clicks again and the compressor should start again.
Most GE's have a diagram on the back that shows componet locations
Sep 22, 2009 | GE Refrigerators
Model BC21VW Amana Lower Freezer works, Upper Fridge not cooling
I want you to see if you can manually get the refrigerator into defrost. At the bottom of the front of your refrigerator and behind the kick plate is a defrost timer part number 10530703 I want you to pull the kick plate away from the bottom and there should be a metal mount with a hole in the center. Take a flathead screwdriver and slowly turn clockwise until the compressor stops. The refrigerator should remain off for about 25 minutes. During that time open the freezer door and listen for crackling and sizzling sound. That should be sounds of defrost taking place. If timer is not working properly you may need to turn again slowly clockwise after the 25 minutes and replace the timer. The only other 2 things that may be causing this is the defrost heater or defrost thermostat inside the back of freezer and behind the rear panel. Try this first and let me know what you find, Thanks, Sea Breeze
Sep 17, 2009 | Amana ABB1927DE Bottom Freezer...
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
I need to know where to find the defrost timer on my amana fridge. this is the 22.6 cu. ft model #sqd26vw. Ive looked in the back and found the compressor but no defrost timer. specifically is it in the...
remove the grill at the bottom of the fridge there is a black box wth a knob sticking out you can turn in only one direction clockwise till you hear a click and the compressor and fan will cut off if running.
Jun 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Where's the condencer?
there is a fan located under and behind the fridge. there is a condensor under the fridge behind the front kick plate the fan is used to circulate the air trew the condensor . remove the kick plate at the botom of the fridge and using a vacume with a crevace tool klean the dust out of the condensor..
hope i was able to help. post feadback if so
Oct 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer has frost all over it
what sort of fridge ,single door double door? more information needed
Aug 12, 2008 | Refrigerators
Amana ABB1921DE Bottom Freezer Refrigerator Logo
59 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
