Question about Euro-Pro Steam Generator EP8001 Iron
Generator runs but can't get any electrical power at plug in. Honda EB 1400x
  • 304 Answers
Is there a circuit breaker or reset button. If there is and I'm sure you have checked it you may have to replace it. You can check for power with a power meter before the circuit breaker or reset button. If you have power before break simply replace the breaker. Do you have the owners manual? look in it for the location of this device if you can't locate it. You can get a service manual for it online for 15 bucks. It would be well worth the investment.
http://www.hondapowerequipment.com/products/manuals/default.aspx
cut and paste this address in your internet browser address bar.
I hope this points you in the right direction If you have any questions or thing you want me to know you tried post then here and I will research this matter for for you. please rate me for my research when we get this fixed. Thank you George
Posted on Jul 25, 2008
Hi guys. I have a Hoover ironspeed IS21-1 steam generator iron. I love this iron it's the best steam generator I've ever had but now once it's heated up and I go to use it as soon as I press the button...
Try unplugging everything that is using that circuit because it's possible that you have too many items plugged up. Also try other outlet.
Jan 14, 2015 | Irons
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Is my steam iron broke?
Get a new one. If it drew enough power to trip off your electricity then there is a problem that is not worth taking a chance on.
May 07, 2017 | Irons
Iron doesnot get hot onlyplatform
Try to open the electric iron and locate the thermostat . Secure the electric iron against any metal object that may cause electric shock or short circuit and plug it to a power source. Slowly adjust the temperature and using an electric tester check the power before the thermostat and after the thermostat. If there is a power before the thermostat and has no power after the thermostat then your problem is the thermostat replace it with a new one.
Jul 14, 2011 | Euro-Pro Irons
Iam attempting to fit a new dual cord to my steam generator model 2935 and I have misplaced my drawing of the connections to the iron. Is it possible to get the wiring diagram for the electrical...
The Dual Kilowatt Switch MUST be set to the proper kilowatt rating in accordance and Connect incoming power to floating black pigtail leads labeled "L1" and "L2. keep updated,
Dec 24, 2009 | Tefal Irons
Can't find a part for my DG050 Steam Generator
you can buy them at any electrical store or some hardware stores would have them... take the wire in with you (lablel where each wire goes in the switch or draw a diagram first) or take the whole iron with you. they crimp onto the wire
Mar 18, 2009 | Rowenta Steam Generator DG050 Iron
Plug heating up
Check the power on the label of the iron, usually 1kw or 1200W
Next open the plug, if it has a screw. The fuse inside the plug may be too low should be 13 Amps for an iron of 1KW
Check also whether there is a loose wire in the plug.
If not the take to an electrical repairer for a quote
Jan 23, 2009 | Euro-Pro Shark GI490 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
105 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
