Question about Dryers
Have a "finshing" noise even when drum stops a turn
Maytag dependable care dryer - 1997 or 1998. I have a noise when the drum turns but only when it reaches a certain spot. Also, it will do it when you manually spin the drum by hand when it is off. One thing I noticed is, looking in from the back plate, that when the motor and drum stop, the noise keeps going and seems to be coming from inside the front lint screen cover on the lower left side front of the drum. Could this be worn-out inside motor bearings or the vent blower bearings? Should I replace whole dryer or just motor or lint screen blower unit.?
Thanks,
Bob
I had a similar problem and found a screw had backed out on one of the turning paddles inside the drum but the screw was on the under side , and could reach it through the access door , just had to turn the drum by hand till the screw was in sight.
just turn the drum inside by the paddles and shake them to make sure they are tight , thats how i found my problem and noise
good luck hope this helps , wayne t
Posted on Jul 14, 2008
My maytag dryer is screaming at me!!
It could be the band slipping, depending on how handy you are, you can take out the back cover and check it out while it runs. I am assuming this is an electric dryer, so taking the back cover is not so difficult, just need to figure out what type of screws it has, find the corresponding tool and take it out (make sure power is unplugged while you do this) plug it back it and let it run, you can find where the noise is coming from. If you cannot figure it out, put everything back on and then it is best to call a technician.
Jan 22, 2018 | Maytag Dryers
My Maytag Depenable Care Gas Dryer has become very squeaky when the barrell spins. i took off the front panel and sprayed WD-40 on the backsides with the Plastic wheels and it went away for about 10...
Probably best to grease the wheels (called drum support rollers) rather than use WD-40 because that strips away the lubrication. It will also pay to check the drum support glides under the front of the drum. Worst case you may have to replace the support rollers.
Jun 26, 2011 | Maytag Dependable Care LAT9706
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
Rumbling noise in maytag gas dryer DG110 series 01
Unplug Dryer first: Page 3-11 of full service manual at link below will get front off. The most common solution for your problem is the blower wheel loose on the shaft. Hold drum and see if you can turn blower wheel (lower left plastic squirrel cage) separately. If you can turn the plastic wheel while you hold drum still, replace blower wheel.
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Aug 22, 2009 | Maytag PYE2300AY Electric Dryer
ELECTRIC DRYER MODEL# PDET910AYW
When you turned the drum backwards you caused the belt to come off. Put the belt back on.
While you have it open to re-install the belt check the blower wheel very carefully for the noise. It is probably loose and needs replacing.
Aug 05, 2009 | Maytag Dryers
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Dryer making loud noises
You need a new drum roller in the back of drum housing.
Jun 16, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
