Question about Compaq Armada 1700 Notebook
Help with compaq armada 1700
This is an older compaq laptop. It is a 1700 armada compaq.I think it is either a windows 95 or a windows nt. It says on the laptop designed for microsoft...windows 95 windows nt. I am having a problem that says NON SYSTEM DISK OR ERROR. REPLACE & STRIKE ANY KEY WHEN READY. ALSO THE SCREEN IS BLACK, I got this used. I do not have an instruction manual with this.When I turn on the computer it says this the very first thing. I didnt have any floppy discs or anything in it at all either. Thanks for any help.
    Scholar:
  • 150 Answers
Sounds like your Hard Drive is gone, or you have a floppy disk in drive or cd in drive, could be a CMOS setting wrong also, but I would suspect the Hard drive is shot on a machine this old. P.S. I am running an Armada 1700 right now. Your HDD door should be on the bottom of the machine about 3"X3" with a 1"X3" lip that is hinged and has a catch on it, you need to release the catch and see if it even has a hard drive in the caddy, it will slide towards the front of the machine, slide it back towards the back it is only held in by the cover's foam and may have come dislodged. Some things to try.
Posted on Jul 23, 2008
SOURCE:
DRIVER VIDEO COMPAQ ARMADA 1700
there are so many models of armada 1700
please select your model from below link and then your operating system and it will show you all the drivers.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=96221&taskId=135
Mar 01, 2011 | Computers & Internet
Have a Compac Armada 1700 laptop with Windows NT4.0 After reinstallation of NT4.0 i have only 16 colors on screen. Sombody know how to get 256 colors? Karl Hole Norway
hi
you have not install the Display drivers just go to below link and download the VGA drivers
http://www.laptopdrivers.net/video-drivers-for-compaq-armada-1700/
vote me if you find your solution
Oct 13, 2010 | Compaq Armada 1700 Notebook
I recently bought a fixer-upper Compaq Armada 1700 and was wondering a few things. 1) What is the maximum hard drive space that this model will support? 2) What is your opinion on using Ubuntu on this...
This would use a EIDE disk which generally tops out around 160GB. It is a disk problem not a computer problem. Unbuntu would work a lot better than any Windows OS. I'd go for it.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 01, 2010 | Compaq Armada 1700 Notebook
Hi i have compact armada 1700 and it is missing operating system what is the problem
Hi
If it is missing the operating system then you are missing windows i.e. Windows XP, Windows Vista etc etc
You will need to purchase a CD from any reputable PC shop or online, and then install onto your PC
Mar 08, 2010 | Compaq Armada 1700 Notebook
Can i restore a compaq armada 1952DMT without the disc?
Hi guy1121,
since this type of laptop is a very old one you should think about installing a Linux-system on it.
In case you're still having a genuine and unused MS Windows 98-setup disc you could also try to use that one to install and use your laptop with. In that case you should check before whether HP (they bought Compaq some years ago) is still providing drivers for the laptop and for its use with Windows 98 (which is not very likely).
Good luck and greetings from Germany,
noris017
Feb 25, 2009 | Compaq Armada 1592DMT Notebook
Display problem
have compaq armanda laptop can;t get it to256-color ?try all -change back to 95 windows --have 98 windows both won;t work?
need help
Feb 09, 2009 | Compaq Armada 1700 Notebook
Can I get the internet on compaq armada 1700 laptop?
That phone line will only be for actual phone lines.. as it will be a modem.
If the lappy has an ethernet port (slightly larger than a phone port, but looks the same) you could use that with an ethernet cable to a DSL modem. (the modem has the phone wire plugged into it)
Most laptops have an ethernet port, but yours might be a bit too old perhaps? If that's the case, you can buy either a USB to ethernet adapter (but you might not have that either) or a PCMCIA ethernet card. The latter will definitely work for you, and can be bought second hand VERY cheaply... if not for nothing.
I really hope it has something a bit newer than '95 though... otherwise just getting the internet to work could be a problem. Good luck!
Jul 14, 2008 | Compaq Power over Ethernet 12 Port...
Armada 1700 laptop
remove the battery and power from the A/C and then plug in the battery and a/c cord
Jan 21, 2008 | Compaq Armada 1700 Notebook
Tech help
Forget the diagnostics. If things are that bad then do a complete format and reinstall. Trying to fix problems on any windows platform usually leaves you with more problems to solve. Bite the bullet and give you and your laptop a new lease on life. BMW
May 25, 2006 | Compaq Armada 1700 Notebook
Compaq Armada 1700 Notebook Logo
158 people viewed this question
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
