OK this systems has a safety system and it will not let gas pass threw without the pilot light working correctly. first off near the pilot light there is a thermal coupling. this sends a signal to the main valve to open up. this thermal coupling need to get to a set temp. (hot) this is probably why you don't hear the gas. check if there is a manual bypass valve for maintenance. check if you can light the pilot rite away if you power the system on. it also has a time delay so the pilot won't give gas out if not fired on. sometimes there is a manual nozzle you have to press and hold till the gas pilot warms up the thermal coupling. hope i help some. thank you.
Hi
If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry. Now let the unit run for 2-3 minutes and then you press
the Cancel/Drain button and allow it to completely drain and reset. If this
doesn't work then it's an issue with the wash pump not pumping the water past
the heater efficiently or due to lack of water to heat. Please make sure that
heater is not open circuited and is heating the water efficiently. You'll have
to check the heater using a multimeter; the meter should read between 3000 to
3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure
water pressure is optimum and fill valve is working fine. Hope this helps...
Please post back if you need more information.
Daniel
