Question about Dryers
My idle pulley came off what shall do - Dryers
  • 1 more comment
  • Anonymous Jul 14, 2008
    I opened the front of my dryer and the idler pully was lying on its side in the middle of the bottom of the dryer. I found another belt that was broken up I can't figure where this one goes. I seams to be a gasket of some kind.
    I have taken the front of the dryer and found the idler pully laying on it's side in the middle of the dryer bottom. I also found another small belt or gasket on the bottom of the dryer. I don't have a clue at this time how to fix it back together.
  • robert samples May 11, 2010
    what brand is your dryer there are different prcedures for different dryers
It is a kenmore
Posted on Jul 14, 2008
How are the idling pulleys located
idling pulleys = a pulley which only provides a turning place or adjusting place for belts, has no shaft attached .-- these pulleys can be under covers on deck can be stacked with more idling er pulleys, just depends on how many blades are being used
Jun 13, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Shall I remove my car's battery terminals if I leave it idle for 2 weeks
why are you running your car for two week non stop? and sure its not like you want to hurt anything.
Sep 03, 2012 | Cars & Trucks
How do i put my a/c pulley back in and belts?
A specific routing diagram label should be locatedunder the hood of your vehicle.
Oct 08, 2011 | 1996 Mitsubishi Galant
96 galant cant put the a/c pulley or belts on how do i do this?
The easy way to reset the belt back to the AC compressor and the crank pulley is to loosen the IDLE pulley on the threading path. Use the correct wrench to loosen the fitting on the engine body, now pass over and thread the belt over the mainpulley and the AC pulley through the idle pulley, use a small lever to tighten the belt holding up while you are able to tighten the idle pulley.
You might need help to hold the tension while the idler is fixed.
Oct 08, 2011 | Cars & Trucks
I need to replace the alternator belt on a 1994 Volvo 940T, but can't get the A/C belt off so I can remove the alternator belt. Apparently there's an adjustment bolt on the compressor that I...
Unscrew the idle pulley first.
Look for a small pulley where the a/c belt passes through. That is the idle pulley, the screw on the bracket of that idle is on the top side where you could adjust to loosen the tension of the belt. Before loosening it, loosen the bolt on the front of idle pulley.
Hope FixYa helps you out!
Aug 28, 2011 | 1993 Volvo 940
I cant get enough slack to slip it over the alternator pulley once i torque the belt tightner
Try loosen the "belt tightener" idle pulley, slip belt over alternator pulley, THEN tighten the idle pulley to tension the belt.
Jan 18, 2011 | Chevrolet Monte Carlo Cars & Trucks
How to change belt on a 98 pontiac bonniville
You are asking how to remove the serpentine belt on your 3800 engine ?
First, I would take several pictures so you know how it goes back on.
1) * You must have a special idle pulley tool. Take you tool and pry the idle pulley enough to remove belt, dispose of old belt.
2) Now place the new belt on the pulleys just as you see in the pictures you took or look at the diagram on the radiator support.
3) Pull the idle pulley again with your tool and put on the belt.
The idle pulley will put the tension in the belt.
Please let me know how it went.
Feb 08, 2010 | 1998 Pontiac Bonneville
My bottom pulley came loose
In Pocceson of Stolen Properties. Properties are belongs to me. Somebody stole them and sole it to another person.
Dec 14, 2009 | 2000 Chevrolet Impala
Dryers Logo
Top Dryers Experts
