Question about MSI RS482M4-ILD Motherboard
USB Ports Stopped Working
When speaking with my daughter, she advised all USB ports have stopped working, and the computer running very slow.
While speaking with her, I asked she run Task Manager.
With no programmes running the processor was at 100%, I asked her to enter the BIOS and disable USB, by doing this the processor dropped to 3%.
The time the USB's began to fail is as follows -
One of the ones in the front stopped working about 6 months ago. The other one stopped working about 3 weeks before all the trouble started, (computer running slow). When that one stopped working (other front), we started using one of the back 4 ports. One of the back 4 had the printer connected the other had the mouse which left 2 ports to use. All 4 of these stopped working at the same time about 2 weeks after using them.
In the BIOS the following changes were made -
I have turned off 3 USB root hubs. The USB PCI controller is on and 2 standard USB is on.
The USB in the BIOS is now enabled and the computer running OK except for no USB ports.
I would appreciate some advise.
kevsim
  • 1 more comment
  • kevsim Jul 16, 2008
    Bubbabear64,
    Thanks for the information.
    The only BIOS available is the same as existing.
    A little more information -
    The 2 USB’s that are on are standard open HCD USB host controller. If I go to device manager click the 2 USB that are the same then click properties it comes up under general tab
    Device type: Universal serial bus controller
    Manufacturer: Standard USB host controller
    Location” PCI bus0, device 19, function 1
    The other USB that is turned on is and 1 standard enhanced PCI to USB host controller. When you click that under properties is says
    Location PCI bus 0, device 19, function 2
    I would appreciate a little more advise.
    kevsim
    Bubbabear64,
    Because of the computer running like a snail and no USB ports along with the processor running at 100% System, a full check for Virus, Adware and Spyware was carried out, nothing was found.
    It was the decided to reinstall the operating system but first use "Dariks Boots" to completly clean the hard drive before reinstalling.
    This took a very long time, presumably because of the processor running at 100% System.
    Upon completion the processor was still running at 100% and no USB ports,
    The above was then carried out re switching off the USB's.
    With the above information provided, are there any other possible fixes?
    kevsim
  • kevsim Jul 17, 2008
    Bubbabear64,
    Is there any software that could be run for testing the Motherboard for USB problems?
    kevsim
  • 2,794 Answers
Check in MSI.com and see if there is a firmware upgrade for that particular motherboard.
Posted on Jul 14, 2008
  • 1 more comment
  • Tim Babcock
    Tim Babcock Jul 17, 2008
    Check in the BIOS setup. Make sure that all caches have been enabled. Make sure all information in there is correct as well. Anything that does show up hardware wise could be suspicious.
  • Tim Babcock
    Correction, anything that doesn't look right hardware wise could be suspicious.
  • Tim Babcock
How do you open a port
  1. USB ports stopped working Acer Aspire 5750 - Tom's Guide
    www.tomsguide.com/.../usb-ports-stopped-working-acer-aspire-5750.ht... Apr 23, 2014 - USB ports stopped working Acer Aspire 5750. Tags: Aspire. Laptops... I have an Acer 5750 none of the USB ports work I tried disabling them all ... on Acer Aspire 4935 laptop Forum; Acer Aspire Computer - USB not working ...
Jul 11, 2015 | Acer Aspire Computers & Internet
My dell latitude d600 usb ports stopped working how can i get it fixed. thans
If ALL the usb ports have stopped working, this is a problem with the USB controller. The short answer is that you cannot easily repair this. In all probability, the controller, or a circuit trace to it has blown or shorted. You would need to get another motherboard.
If one is still working, then you can get a PCIMCIA card to usb port that will give you 2-4 extra ports, but this will only work if at east one of your existing usb ports is still functioning
Aug 16, 2011 | Dell Latitude D610 Notebook
Usb ports on side of monitor HP w2228h not working?
the two usb ports on the side of my hp 2207 h monitor stopped working?
Mar 21, 2009 | HP Computers & Internet
Gateway USB ports stopped working
So maybe you need to install the drivers for the USB device you are trying to connect. Also, with the computer off, try cleaning all USB ports and plugs. You can buy electrical cleaner in a spray can at Radio Shack. Let it dry thoroughly before powering up. But to me it sounds like a driver problem. Unless maybe your USB BUS is going bad.
Jan 06, 2009 | Computers & Internet
ALL uSB Ports stopped working
If new BIOS will not help, then
Motherboard needs service.
Dec 29, 2008 | HP Pavilion dv9000z Notebook
USB outlets
I'm assuming you are speaking of the USB ports on the Monitor?
Do you have the USB cable running from the back of your computer to the back of your monitor? For those ports to work, you need a USB cable that runs from the computer to your monitor. This is a cable in addition to the power cable and the video cable. Verify you have three cables connected.
If you are not speaking about the USB ports on the monitor, please advise...
Aug 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
USB Ports
I would go back to device manager and uninstall all drivers in the USB category. Reboot and Windows will re-detect all the USB ports, this should work. If it was an electronic problem then some ports would work and other wouldn't but not all since there is multiple USB controllers in most computers these days.
Jun 16, 2008 | Toshiba Satellite M35X-S114 Notebook
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Usb ports
You'll want to verify your computer recognizes your usb ports.
In device manager, look to see that you don't have anything with an exclamation mark, question mark, or red X on it. Make sure you have the usb ports listed under Universal Serial Bus controllers. If nothing shows, your usb ports may be dead. Depends on the age of your computer and what might have happened to them.
Device manager- right-click My Computer and go to properties, then select the hardware tab.
Jan 28, 2008 | Acer TravelMate 2300 Notebook
Usb ports don't work
Reinstall your USB drivers:
Navigate to Device manager, find a branch named "USB Controllers" or similar
Right click the one thats the problem (or all of them if you dont know which), select Uninstall
Reboot your machine and windows will autodetect the USBs and reinstall their drivers.
Jan 15, 2008 | HP Compaq Presario V2000 Notebook
MSI RS482M4-ILD Motherboard Logo
467 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
