Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm - soap drawer is stuck and will not open
Thanks
  • 6 more comments
  • fiberguy3 Jul 14, 2008
    Our soap drawer is stuck as well.  Called LG, and that was a useless call.  It is like one of the removal trays has lifted and is catching on the inside.  Lg also said tat the service tech are just going to push and pull the drawer until it opens.  Have already tried that and the front of the drawer has come off.
  • flipper-love Aug 10, 2008
    Did taking the lid off work? I'm having the same issue.....
  • vatrails May 11, 2010
    The solution entered Nov 26th was great. I was able to fix my washer and I removed the softener box. It now works just fine and the soap dispenser moves easily. Saved me about $200 as I just had this repair done by a repairman 3 months ago. Note the four screws referenced are holding on two plastic clamps. There are two screws in each clamp one over the other. (just in case you can't actually see what you are doing.
    Great advice. Thanks again
  • susanbholmes
    susanbholmes Apr 15, 2012
    Thank you! Did all the suggested steps, got it all back together, works. So happy not to have a service call and expense. Happy with self for following the directions and making it work! Thanks again. Recessionista
  • G Townsend Jan 05, 2013
    Just tonight had our LG washer soap dish get stuck. The drawer only came out about a quarter of an inch. We followed the instructions and removed the fabric softener tray. This information saved us a minimum of $100.00 for the service call alone. Thank you.
  • Norman Farrar Jul 24, 2015
    Great solution, easy to follow, and complete the fix, did not find black wire to disconnect, but the rest was as described, did not have to put screwdriver into back of box to release lid, just lifted white ''box'' top slightly after releasing clips and drawer slid out. Thanks for solution, hope it is permanent.
  • BeasBabe Feb 24, 2017
    Wow! Easy peasy! Just had to loosen the lid on the white holder and it freed! Thanks!
  • Jeannine Galloway
    Jeannine Galloway Apr 19, 2017
    So of course if it is stacked, you're out of luck!!
This is caused by the "Fabric Softer" removable tray inside the drawer getting stuck in the top of the drawer cabinet.
Solution:
1. Unplug machine
2. Remove four sheet metal screws and plastic plates from top of back of machine that hold the "lid" on (perhaps yours is different and only has two screws, but that's your world :) )
3. With the palm of either hand hit the both sides of the lid of the machine at about a 45 degree angle towards the back of the machine until the lid slides back about 4 inches
4. Gently remove lid (will lift off easily if you've freed it correctly)
5. On left you'll see a white box which is the cabinet for the drawer. Carefull pull the black wire from it's retainers
6. Lift up the three clips on the right side of the cabinet that hold it together
7. In the back of the cabinet, grab ahold of the plastic piece that doesn't have a hose attached (unless yours does, in which case figure it out yourself :) ) and gently pull up until you can see the cabinet coming apart in the back.
8. When you have enough clearence push a screwdriver through the opening you've created while lifting on the back of the cabinet apart, and PRESTO! The drawer will pop out.
This will happen everytime from now on if you do not remove the the "fabric softner" tray from the drawer. It is a design flaw that will happen to all models eventually. If you must have that little tray, then find a solution that works and post a follow up here (I imagine it will involve a bench grinder :) )
HAPPY WASHING AND BUY AMERICAN!!!
Posted on Nov 26, 2008
  • 7 more comments
  • jparson2 Jul 18, 2011
    I used some 220 grit sandpaper to take about 1/32" of the top surface of the tray and also took a bit off any edge that might have been hitting. I am not sure which area needed the work, but after the sanding / filing, the tray once again slides in and out freely.
  • thezguy
    thezguy Sep 08, 2012
    Following your instrutions to open the washer were great! I had the added disadvantage of having the dryer stacked on the washer with a special kit. However, one I got to the outside of the fabric softener tray, I unsnapped the 3 hold downs, which gave just enough clearance to remove the tray. Once I had the tray out, the problem became obvious. The tray top for the fabric softener dispenser was warped about 5/64ths. The choice was to not reinstall the dispenser cover or force the front edge to stay in place. I chose to drill two holes in the cover thru to the liquid container assuring I avoided the dispenser hole and just screwed the front of the cover down and it now works fine.
  • terriminter5
    terriminter5 Jan 12, 2013
    You just saved us a call for a technician! This was PERFECT!! We fixed it!! :)
  • Wendy Feb 28, 2013
    yes thank you, had the same issue, aint that something for such an expensiveproducts!!
  • punkbyplasma Aug 13, 2013
    whew!!! That was just great instructions.. It took me a while becasue I was afraid I would destroy something but after that >> I was good. It worked...
  • Erica Trammell Jan 11, 2014
    Thank you! This helped us! We discovered mold when we removed the drawer. :-(
  • Amanda Marie
    Amanda Marie Mar 27, 2014
    Great instructions!! Thank you!!!
  • Nancy
    Nancy Jun 03, 2014
    Thanks, this did the trick. I want to add that rust and corrosion may develop under the dispenser drawer on the front of the machine. The corrosion can raise the drawer just enough that it causes the inside of the drawer to catch on something inside of the dispenser and won't let the drawer come out. If your machine has corrosion, use a file or sandpaper and remove it.
  • Laura
    Laura Dec 04, 2015
    You are a genius! Thank you!
After you have the drawer freed up, take the small blue plastic cover of the fabric softener tray and file or grind a 45 degree bevel across the top leading edge of the blue plastic cover and you can then put it back in place and not have the trouble of it catching on the top of the drawer enclosure. The bevel will cause it to move down when it strikes the plastic rib it formerly caught on.
Posted on Dec 26, 2008
  • David Reinknecht
    David Reinknecht Feb 27, 2017
    Had the exact same problem and the fix worked perfect! Thanks
I have an LG TROMM WM2016W I accidentally dropped a lid into the detergent spot in the drawer and can not get it out. How do I remove the drawer ?
Posted on May 16, 2010
    New Friend:
The disassembly was just as Pagentegan described. For me hand filing the edge of the softener insert did the trick and I am not having any more problems with it. I attaching pictures to show how much i filed it.
LG Tromm - soap drawer is stuck and will not open - lg-tromm-soap-drawer-stuck-will-not-open-clb3gos3sbfvasioy3ymppq1-4-1.jpg
Posted on Mar 18, 2015
  • Anonymous Oct 12, 2015
    just filled ours down ... works great
    New Friend:
Great instructions on disassembly. Thanks. The fix solution, however goes to my wife. She is a genius. It's soap scum on the bottom of the fabric softener lip which will " eventually get us all because it builds up over time and prevents the lid from seating properly. Clean the groove in the bottom of the lid with some hot water and an old toothbrush and you're good to go.
Posted on Jul 26, 2013
The best solution was posted Nov 26.  We have now fixed our machine and saved the service call.  The service center lied about solutions and said that the only solution was to break the drawer and buy a new one.
Posted on Dec 28, 2008
  • John F White
    John F White Jan 19, 2016
    That is the same thing the tech told me. Break it!
    Champion:
  • 210 Answers
Try taking off the lid, maybe you can bang it down or jiggle it loose. 2 screws on the back and slide the lid backwards, unplug unit first.
Sgt 48
Posted on Jul 20, 2008
    New Friend:
I was able to fix mine as described above
Uncrewed back , slid cover back and took off. I only needed to loosen the tabs on the detergent housing to get my door open. I washed out all the drawer inserts and left out the bleach cup in my case.
Posted on Jun 08, 2016
    New Friend:
Do what I did....take the softer tray OUT and start using DRYER SHEETS. LOL
Posted on May 03, 2016
    New Friend:
I followed previous instructions to remove the top of the washer. Then removed the black wire harness on the right side of the dispenser cover. I un-clipped the 3 tabs on the right side and lifted the back right corner. I could not see any evidence of the blue covers catching so my solution was to cut up a plastic milk jug and take to small squares of plastic ( 1 inch square) I put them together and folded them in half. I then lifted up that back right corner and slid the folded plastic peices in between the dispenser cover lid and body. This shim creates just enough lift that the dispenser now slides in and out freely.
Posted on Sep 26, 2015
    New Friend:
Pagantegan's fix did the trick for me. I also beveled the leading edge of the softener tray just as Joel Olson posted. I did find an additional factor that was making my problem -- the "nozzle" on the blue cover was too loose, which was allowing the plate pop up and stick.
My fix -- on the white nozzle on the tray, there are 3 "fins" that come off the nozzle (I guess they're offsets to keep that area open for the water to drain out correctly). I used a hot glue gun (yes, a hot glue gun) and added a little bit of rubber to just one of the fins to build it out more. I let it cool before I tried the cover -- I didn't want to glue it down, just make it fit tighter. I thought I would have to add rubber to each of the 3 fins, but it turned out that adding it to just one of them did the trick.
Now the fit is snug but the cover is removable, and the beveled edge of the cover plate rides under whatever it was snagging on inside. Thanks to all contributors for saving me several hundred dollars!
Posted on Aug 18, 2015
    New Friend:
Was helpful, however, my washer and dryer are stacked. And I can't move them.
Posted on Apr 08, 2014
4 Suggested Answers
SOURCE: I have LG TROMM WM1812CW soap leaks out from
For the owners manual go to
http://www.lge.com/us/appliances/washers/index.jsp
and search for your owners manual by part #
Posted on Nov 21, 2009
Daniel S
  • 4323 Answers
SOURCE: LG TROMM WM2277HW Problem:
Hi
Try and disassemble the dispenser & check the wiring to the dispenser housing--
1. Disassemble the top plate assembly(Unscrew 2 screws on the back of the top plate).
2. Pull out the drawer.
3. Push out the DISPENSER ASSEMBLY after unscrew 2 screws.
4. Unscrew the nut at the lower part of the dispenser.
5. Disassemble the 4 connectors from the valves--
Wire Color
Blue Housing (OR-BK)
White Housing (WH-BK)
Blue Housing (GY-BK)
Red Housing (BL-BK)
6. Unscrew 2 screws from the back of the cabinet.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 27, 2011
SOURCE: lg tromm soap dispencer won't open
sofener cover (blue) cap @ not seated or worn
Posted on Mar 06, 2008
Animaljam member codes
outback - 500 gems (thanks disqualified!)
ajrocks - 500 gems (thanks southernwolf03!)
pets - 500 gems (thanks iamthecat!)
winter - 500 gems (thanks Cali Girl!)
ajbday4 - Animal Jam 4th birthday cake
ngk2015 - 1000 gems
adventure - 500 gems
tigris - 500 gems (thanks fish301!)
ganges - 500 gems (thanks ARCTICKWOLFGIRL!)
chimbu - 500 gems (thanks Nikola!)
drawing - 500 gems
shadows - 500 gems (thanks Abby!)
explorer - 100 gems
Feb 06, 2015 | Computers & Internet
What are the animal jam gem codes?
Below is the most recently updated list of codes available on animal jam in 2014!
kama - 500 gems
thanks - imprisoned phantoms
ngexplorer -1000 gems
friendship - 500 gems
zambezi - 500 gems (thanks ARCTICKWOLFGIRL!)
nile - 500 gems (thanks Lucas!)
drawing - 500 gems
Alphas - 500 gems
bemybuddy - 500 gems
explorer - 100 gems
ajbday3 - Animal Jam 3rd birthday cake
10million - 10 million banner
Jul 13, 2014 | Video Game Consoles & Games
Animal jam codes of 2014
kama - 500 gems
drawing - 500 gems
Alphas - 500 gems
explorer - 100 gems
Jul 11, 2014 | Video Game Consoles & Games
2014 codes for animal jam
kama - 500 gems
drawing - 500 gems
Alphas - 500 gems
explorer - 100 gems
You can find the latest codes here: http://www.animaljamworld.com/codes/
Here is the list of codes:
kama - 500 gems
drawing - 500 gems
Alphas - 500 gems
explorer - 100 gems
Jul 10, 2014 | Video Game Consoles & Games
Codes for animal jam
Here is the most recently updated list of codes available on animal jam in 2014. You can check for updated codes here: http://www.animaljamworld.com/codes/
kama - 500 gems
drawing - 500 gems
Alphas - 500 gems
explorer - 100 gems
Jul 09, 2014 | Video Game Consoles & Games
DV2000
Don't post any solution saying Thanks or anything. Only post if you have a problem. If you're going to thanks, then thanks on that thread (problem) instead of wasting your Time!
Sep 12, 2008 | HP Pavilion dv2000t Notebook
How do I turn off the write protect on the verbatim 4gb flash drive?
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 17, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
System error E000
That's was a miraculous!!!!! My canon Image Class D860 is brand new now after following the steps.
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
This just worked for me on a D860
Thanks
Evenel
May 07, 2007 | Canon imageCLASS D860 All-In-One Laser...
Washing Machines Logo
16,997 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
