Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not getting cold
I have a whirlpool estate side by side the fridge side does not get cold and there is frost on the back of the freezer side
    Scholar:
  • 50 Answers
This is a frost free frige, so if you see frost, that is the problem. Check the defrost heater, defrost limit and defrost timer/board. You can get by for a while by manually defrosting the fridge. Turn it off, unload the food, and leave the freezer door open for 24-36 hours.
Posted on Jul 21, 2008
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Apr 30, 2014 | Refrigerators
Whirpool side by side freezer working but fridge not
Hi emmaubiera86,
The issue with the freezer working but the fridge is not is usually the result of a defrost problem. The first thing to check in this case is the freezer area. Look at the back panel inside the freezer. If you notice frost covering the back panel, you have defrost problem. One of the things that happens during this defrost problem is Air cannot circulate from the freezer(where the cold happens basically) to the fresh food section. The coils inside the freezer are the only part inside the whole refrigerator that "get cold". They need to stay free from excess frost build up so that air can pass through the coils and reach the fridge section of your machine.
Hope it helps.
Thank you for using FixYa.
May 07, 2011 | Whirlpool Refrigerators
Whirlpool estate, is no longer cold, for the freezer or icebox
hi,
pull it out and study the back of the fridge down where the cardboard cover is, ((careful of the water line)) sometimes the cardboard cover will come loose and get in the way of the small fan back there, if it does , it will do that, if thats not it, probably your best bet will be to call and have a guy come out and test it. craigslist has cheap side by side fridges, since theyre such a pain to replace..
good luck
J
Jun 26, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Freezer cold, fridge part cold at first then warming
hi friend
it is fan problem check it....it may also be a thermostat not working proper,,check them both ,
thank u,,,,,,,,
May 03, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
MY FREEZER FREEZING AND FRIDGE IS NOT COLD ON MY BLACK SIDE BY SIDE WHIRLPOOL
hi thanks for the question i would check to see if the fan in your freezer is working that could be the problem make sure the back of the fridge is clean where the compressor is located also make sure no frost has built up in freezer thanks the appliance doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool fridge with top freezer.( no ice maker )
check if you have frost build up at the back side of the freezer section.
if you do, then it is a defrosting problem.
you could have a problem with the defrost timer, the defrost heater , or the bi-metal.
if there is no frost accumulation, that would be something more and you have to elaborate on what you observe with the unit to help me further troubleshoot your unit.
tnx 4 using fixya,
drcool
Sep 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
192 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
