Question about Roper REX4634KQ Electric Dryer
Moisture sensor not working
Can I replace this or repair this myself of do I need a repairman?
Thanks
  • oldfixer May 11, 2010
    why do you suspect sensor ?? if long dry time suspect vent to outsideif timer not advacing ck timer motor for continuity ..motor is controled in auto cycle on some models by wire from element hilimit others by metal contacts inside drum
  • Roper Master
  • 8,220 Answers
No parts needed for this repair! Get a warm damp cloth and reach inside the rear of the dryer and clean the **** off the 2 strips of metal in the back called sensors. Next get the rear of the timer panel off and yank out the small computer board next to the timer. This is the moisture sensing board. Get some alcohol and clean the copper contacts. Shove the board back in and retry.
Posted on Dec 16, 2008
My dryer does not completely dry the clothes when we use the dryness sensing option. It does fine when we use the timer. Is there a moisture sensor that I might be able to replace ?
Dryers with electronic control and auto dry cycle indeed use moisture sensors for the auto drying to work. The problem is absolutely associated with the failure of the moisture sensors, especially when the timed dry cycle works fine. Either the connection of the sensors to the electronic control is loose or the sensors are covered with thin film that prevents it to sense the proper moisture content of the clothes.
Clean the moisture sensor bars thoroughly and make sure its connections are snug fit. Reseat the connections several times to clean off dirt and corrosion build up in the connectors and terminals. The last thing to look into is the electronic control if all resort fail to address the issue, that is, clean sensor bars and good terminal connections.
Indicate the exact model number of the dryer should you need further or more specific troubleshooting and repair advice.
Jun 12, 2010 | Estate TEDX640JQ Electric Dryer
Our Superba (what a joke) Model KEMS308 / KEMS378 has the exact same temperature probe problem where the plug where the probe is inserted is supposedly getting dirty BECAUSE THERE ISN'T A COVER OVER IT...
Common Problem, design defect allows moisture or corrosion on terminals, to cause this problem. Two ways of repairing this. 1: Plug probe in, hang probe out the door, input 160 degree probe temp, turn convection bake to 450 degrees and let it bake for a while. Turn unit off, unplug probe and test to see if the problem is resolved. If it is moisture, the high heat bakes out the moisture and resolves the issue. We have also had some luck with a hair dryer blowing on the probe receptacle to dry out the receptacle. 2: You can pull the entire unit out of the wal with the power off at the circuit breaker, remove the backing panel, and disconnect the wiring to the probe. Some units you have to remove a side panel instead. You won't be able to use the probe in the future if you do this, and you do have to insulate the wires terminals or plug. As always, if you don't know what you are doing with electricity, call a technician to do this repair, it is better to be safe. Also as an aside, I work on all brands of ovens and we find that the Kitchen Aid models have the fewest repairs and the greatest reliability, everybody has design defects and most of the other brands have deliberately built in these defects for faster replacement. The only advice on the Kitchen Aid units that I recommend is that when you do replace it that you buy a separate oven and seperate microwave oven. Most microwave ovens are only lasting 8 to 15 years before major repairs, yet the ovens last 30 to 40 years. Good Luck, Appliance Specialists
Jan 03, 2010 | KitchenAid Architect® KEMS378S Electric...
We just recently bought it used and had it moved. Now there is a constant shadow and on words its even worse. I can't get into the program to align it manualy. Can I find a way to do it myself or do I need...
Most likely a repairman - but review the info below to determine
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 28, 2009 | Philips 55PP9401 55" Rear Projection...
It heats, but won't shut off when using the moisture sensor
The moisture sensor is shot and needs replacing It works till it sees dry air going past it (As set by the maker)if it thinks the air is still moist it will keep on trying to dry it. Call out a repairman or buy a sensor and fit it yourself
Jun 07, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag MDE7400AYW taking 2 or 3 cycles to dry
it's probably your sensor assembly. go to www.repairclinic.com/Appliance-Parts?s=t-MDE7400AY-%3d%3d&z=100 . That is the best possible solution and not too expensive. Good luck.
Apr 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Once I discovered that the problem was not the dryer, I went into my crawl space and discovered the plastic duct was clogged with lint. Apparently the duct was not changed since the house was built over five years ago! The 4" duct was also duct taped to a 3" connector. Additionally the line ran into the crawl space at a 90 degree angle in a space that was only 2" wide! My husband adjusted the way the line ran into the crawl space and replaced it with a rigid aluminum duct. The auto sense works on my dryer and it takes only 30 min. to dry a load of laundry instead of 1-1/2 hours!
Dec 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Replacement interior bulb socket
First off its the repair mans problem not an electrican, he probably knows its a hard job and does not want to do it, probably be alot of work to replace it, check with Victory an see it a replacement part is available an ask how hard to replace.
Nov 11, 2008 | Victory Freezers
I have an f3 code coming up on my stove. the manual says to call a repairman..the stove is 9 years old it may not be worth the repair. can you tell me what this f3 means...thanks
This error indicates the Oven temperature sensor has failed,
You will need to replace the Oven temperature sensor (RTD).
This part can usually be replaced from inside the oven.
Jun 22, 2008 | Maytag Kitchen Ranges
Magnavox 51MP392H
If you checked the batteries, thats about all you can do unless you want to get a schematic, and trouble shoot the remote if you have electronic know how. go to http://www.remotes.com and enter your model number to see how much an original replacement will cost. A universal should work for the power volume and channels, but will not work for the menue or setup.
Sep 12, 2006 | Philips Magnavox 51MP392H Rear Projection...
Roper REX4634KQ Electric Dryer Logo
187 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
