Question about Hotpoint Ultima WF860 Front Load Washer
Washing machines f14 fault code
    Scholar:
  • 97 Answers
Hiya
i take it this is a washer dryer, as the fault code f-14 is the dryer heater.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 01, 2008
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
I keep getting error code F-14 on Hotpoint condenser dryer model CTD85
Hi.
F14 means that control board does not sense that machine is heating:
F14 - A fault with the water heating has occurred
When you get F14 the fault is usually either the thermistor or the heating element (electric dryer). Both parts are tested removing the part from the dryer and reading impedance at the part contact. If the part returns infinity, then the part is defective. If you need to contact a qualified technician use the phone number listed on your owners manual or check Hotpoint website.
Regards.
Ginko
Sep 20, 2011 | Dryers
Hi my machine has come up with a F11 and an F14 fault, its a whirlpool hdw 1011 could you tell me what the fault is with? thanks
Circuit Board Medics can rebuild the CCU with upgraded parts to eliminate the F11 and F14 error codes. Find more details and contact information at www.CircuitBoardMedics.com.
This video shows how to remove the CCU from the machine:
Jul 06, 2011 | Whirlpool Washing Machines
F14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does error code f14 mean on a zanussi bwm129
I believe that is a indicator of flooding of the machine. I also believe if you remove the bottom front panel you will find a sheet of paper with fault codes. While the front panel is removed, unscrew the cover on the water pump filter, check for restiction.Have a shallow pan to catch water and towels to absorb water that will be present
Nov 07, 2009 | Washing Machines
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F14 error code, and says Flooding. Help please.
F/14 ERROR CAUSES DUE TO:--EEPROM ErrorThe Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU. If there is an error reading this data, it will cuse this error.
TO RESLVE THIS ERROR MANUALLY TRY THIS BEFORE CALLING ENGINEER :--
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
May 06, 2009 | Washing Machines
Getting fault code f14?
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 15, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
144 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
