Question about Frigidaire Dishwashers
My dishwasher has water in the bottom and the electronic pad is lit but the wash light is blinking. Anytime I try to cancel and restart the light blinks. I removed the basket, cleaned out the trap and it will not start.
    Scholar:
  • 170 Answers
Get a shop vac, vacuum out the water in the bottom and check the drain hose and make sure it is not kinked or obstructed in some way, not allowing water to drain out of the machine. If you can 'unplug' the machine or turn the breaker off for a short period of time, it may allow it to 'reset' and start the cycle over. Good luck!
Posted on Jul 14, 2008
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Tip
Thanks for the advice, it worked! For a few days I tried to cancel the blinking...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Sep 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My viking vdb325ss dishwasher runs for a few minutes and then stops with control pad lights blinking. The "normal cycle" and "pots and pans" lights blink together. I have reset and restarted the dis
Hello Peter!
Your owners manual or a call to Viking should help you decode the blinking panel lights. They are not random and are a desperate cry for help from the machine.
It has been my experience (YMMV) that a common dishwasher problem in older machines is accumulated grunge (the technical term) in the water level sensor. In many cases the sensor lives in a plastic container on the side of the DW and although the designers try hard to avoid contamination, the container eventually loads up and intermittently jams the float.
Before I pulled the unit however, I'd check the bottom of the wash cabinet for contaminants. There may be an screen (under a cover plate) that has clogged.
Your situation sounds a bit different, since my Samsung did not pump out water, it just stopped and flashed a code, but who knows? Go for the low-hanging, common issues first.
All the best.
Nov 23, 2014 | Viking VDB325SS Dishwasher
Cancel light blinks maytag dishwasher
Check door switch. Also, the control pad may be shorted from water getting in between the plastic and corroding the connections to the buttons. DW
Apr 11, 2014 | Maytag Dishwashers
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
The start button will not stop blinking.
I hit start and then it started operating in test mode and ran through some tests. I now seems to work fine.
Jan 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher blinking light
I have a solution. For Kenmore Dishwashers begining with model 587 and the flashing washing light.it will not start.
inside the front door there are two black and two white wires that lead to the handle. this connection is an on/off saftey for the door latch and if wet will short. The light is flashing because the machine thinks the door is open.
these connections on my machine are very loose. a needle nose pliers to tighten the crimps clean the prongs recconect hard reset at breaker box and you should be ready to go.
m
Feb 01, 2008 | Dishwashers
Dishwashers Logo
87 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
