Question about Meade LX200GPS Telescope
12'' LX200 classic
After getting a two star alignment (as usual) my scope no longer tracks. I used the scope the night before and had no problem. Please advise, thanks.
Jerry
    Genius:
  • 1,027 Answers
Check the time clock battery - it is behind the front panel. If it is dead, then the clock is off, and the alignment will not complete properly. Regular watch lithium coin cell.
Posted on Jul 15, 2008
Procedure to set up a meade 12" LX200R on
It's pretty much all spelled out in the manual. Here:
http://www.meade.com/manuals/TelescopeManuals/LXseries/LX200-ACF_manual.pdf
You should train the drives, and purchase a separate 12 volt power pack with the correct cigarette lighter style power cable. Calibrate motors BEFORE you train the drives with the same power source you will use outside at night.
If this is a GPS model-- and new--- I would execute a RESET on the hand controller-- calibrate motors and train the drives and take the scope outside and get a Satellite link and do a two star automatic alignment.
Make SURE you are centering the correct alignment stars. By the way TRAINING must be done in alt az mode before you put the scope on a wedge-- it cannot be done in polar mode.
Sep 18, 2011 | Meade 12 Inch LX200R f/10 Advanced...
Hello my name is greg i have a lx200-acf from my dad when he passed away do not no howto use it ?
This is a great scope. I have a much smaller version :)
1. Take it out on some dark night. 2. Let it auto-align 3. Select something to look at using the AutoStar II 4. Press Go.
Gander at the wonders of the universe.
In the AutoStar, there is a program called Sky Tour. This will pick some things out for you.
Start with a "wide" eyepiece - to see more of the sky. Work your way to high powers as you need or as sky conditions permit.
Goto a few local "star parties".
Jun 02, 2011 | Meade 12 Inch LX200ACF Advanced Coma Free...
I have 8" LX200 about
You have GOOD power? You can try and replace the hand controller cable--
I would also Calibrate motors, and retrain the drives. But re-training must be done in alt az mode.
Mar 14, 2011 | Meade LX200GPS Telescope
Hi ive got a galaxsee tasco telescope but im having trouble seeing anything at night, i've took all the caps off lined up on a star but its just pitch black can you help thanks.
1. During the day, point the scope towards an object and align the finder scope to the telescope.
2. First object at night should be the moon. it will verify your finderscope alignment and you should have a clear view of the moon.
3. Use your lowest power eyepiece (largest number in mm) and point the finderscope to a star. The star should be in the center of the eyepiece.. If not, adjust the finder until it and the scope are centered.
4. You can use your higher power lens on the star nd it should still be in the FOV (field of view)
5. Scope may need to be aligned (collimated). Instructions on this should be included with the scope
Mar 10, 2011 | Tasco Galaxsee 46114375 (375 x 114mm)...
My meade LX200GPS can't track the stars? wheater the bad weather of observation points will affect the accuracy of automatic alignment? how can I improve the tracking
You must Calibrate motors using the same power source as you use at night outside, then do a TRAIN drives. Some of these scopes also have a Calibrate Sensors -- and some do not.
Then do a two star alignment and center both alignment stars. Daylight Savings Time = Yes right now in the USA, check that it is set to YES.
Oct 13, 2010 | Meade LX200GPS Telescope
I need 3 reasons for whythese problem occur and 3 suggestions for remdiation: 1-alignment 2- localization targets 3- focusing 4- tracking
1. Failure to follow the manual and do all the initial setup. Time, date, and site, and usually training the motors.
2. I don't understand #2.
3. Focus until the stars are pinpoints of light. If you see donuts with a dark center you are NOT in focus. Practice during the daytime on a distant object using the eyepiece with the largest number written on it. The moon should be your first target at night.
4. Many things, broken gears, failure to train the scope, grease on the clutches, hand controller is set for terrestrial viewing instead of astronomical viewing so tracking is NOT turned on.
Read my TIPS about GOTO scopes in my profile page.
Jul 02, 2010 | Optics
Meade LX200GPS 16" out of calibration?
Before you panic I would update the firmware/software on the telescope. With an LX200 interface cable you can upgrade the software in your telescope from your PC by going to Meade's web site at www.meade.com
Download Meade's ASU (Autostar Update Utility) and the latest software for your Autostar II absolutely free. You can also use the ASU to add Comets, Asteroids, Satellites, and User Objects to your Autostar II with a few simple clicks of the mouse.
I believe you can get the manual here.
Jun 04, 2010 | Meade LX200GPS Telescope
Calibrating & Aligning the Meade 10" LX200 GPS Telescope in the Southern Hemisphere
  1. Do a Calibrate Sensors
  2. Do a Train Drive in RA and also DEC
This makes sure that the scope is calibrated properly.
  1. Do an AUTOMATIC ALIGN
  2. when asked to center star, look for the BRIGHTEST star that is close to the scopes field of view. It will be that star you need to used the arrow keys on to centre it in the scope eyepiece and press enter.
  3. This star can be as much as a HANDS distance away from the centre of view
  4. If you cannot identify the star it is asking you to use, press the SCROLL DOWN key to choose another star, keep doing this until you see a star you recognise.
That's it!
You can also hold down the MODE key for about 4 seconds and scroll through the scope info. Make sure you have the correct location coordinates ( Lat/Long) and the correct time set.
Select a bright object first such as a planet and GOTO it. Once you have manually centered it in the eyepiece, press ENTER and hold it for 6 seconds, the handset will say " Press ENTER to sync", press enter and you have updated the scope with the coordinates of that object.
Oct 20, 2008 | Meade LX200GPS Telescope
2-star alignment
I also have an 8i, but decided not to upgrade the controls yet. I've had my scope for about four years. I have experienced the same problem and am not sure what what causes it. Some nights, the scope tracks alignment all night, other times it does not. When the later occurs, the only thing that helps is to repeat the alignment picking new targets. One night, I had to repeat alignment 3-4 times. Also, I highly recommend a book by Michael Swanson, "The Nexstar User's Guide". It's an easy read, very specific and keeps the novice in mind. It should be included with every Nexstar sold. Go online to: http://www.Nexstarsite.com. Hope this helps. John
Sep 08, 2008 | Celestron NexStar 8i (600 x 203mm)...
Meade LX200GPS Telescope Logo
173 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
