Question about Elna Quilter's Dream 6003Q
Thread loops on back using quilt stitch
I am trying to use the quilt stitch (number 11) to make a square border on a quilt. Fabric is cotton and batting is 80% cotton/20% polyester. The front looks fine, but on the back there are loops of thread on some, not all, of the stitches. I am thinking that some sort of tension needs to be changed but am at a loss what to do. I checked the manual and it suggested a tension of 8, so I tried that, but still got the looping problem on the back.
HELP????
Ruth
  • ravanza Jul 14, 2008
    Hi there
    Thanks for the idea. the Elna only goes to a tension of 9, so I tried it on 8 1/2, and it did better but still has the loops. Are these maybe missed stitches. looking at things closer, it seems that it occurs sometimes on the straight stitch, too.
    I installed a new needle to see if that fixed it and it didn't. Needle size being used is 90/14.
  • 78 Answers
You need to put more tention into the Corners, Try puttin a tention of 10 into the Quilt. And it should work fine. 10-12 Maximum, don't go pass 12 because it will probably Rip, or Shrill up. Hope this Helped.
Thanks for Using FixYa! -CA
Posted on Jul 14, 2008
  • Tyler Durden
    Tyler Durden Jul 14, 2008
    For a Number 12, I would say 10-12 the best.
I have a Pfaff hobby 1200. When I try to quilt ( it is on an Inspira frame) it sews fine on the top but the bottom side is all loopy. What are the correct tension #'s I can use? I use cotton thread.
It could be a variety of things. Be sure you are using a brand new sharp needle (try a topstitch, embroidery, or microtex needle on woven cotton). Be sure the needle eye is large enough to accommodate the thread weight. Different needles have a different scarf (the groove that is on the back of the needle that runs up from the needle eye). A larger scarf will protect the thread and keep the thread from hanging up on the fabric when the needle is withdrawn from the fabric.
http://www.schmetzneedles.com/all-about-needles/
Also, the upper tension may be too loose if it is still showing loops under the fabric.
Another cause is the fabric being stretched too tight on the frame causing trampolining.
http://www.kimmyquilt.com/tensioning-the-quilt.htm
Frame Quilting
Nov 25, 2016 | PfaFF Sewing Machines
I am using the walking foot for a quilting project that I am working on, however, the bottom stitching is just looping and can just be pulled away from the fabric.
Be sure you are using a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE THE PRESSER FOOT and rethread the upper thread from the beginning. Make sure the thread path is correct.
Verify the bobbin is installed and turning the correct direction in the bobbin case and that the bobbin thread is threaded through the bobbin tension mechanism.
Set the upper tension to the midway point between high & low number--this may require some adjustment for your particular machine.
Pull the bobbin thread to the top of your sewing project before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Re-test your machine on a scrap quilt sandwich (make sure the walking foot is installed correctly and that the presser foot is lowered when beginning to stitch).
Consult the owner's manual for instructions for presser foot pressure. The pressure may need to be adjusted because you are dealing with a sandwich that is thicker than regular fabric.
You may also try changing the type and size sewing machine needle you are using. Using a Top Stitch or Microtext needle will help the needle to penetrate the fabric sandwich easier. A Top Stitch needle has a larger groove to protect the thread as it pierces the fabric which helps prevent looping.
Also, verify the thread is not too small for the needle's eye.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwil1tu2mb3PAhVR6mMKHUlvB_4QFggoMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Oct 02, 2016 | Sewing Machines
My top thread on the mega quilter keeps looping big loops on the backing and the quilt is on the frame. How do I fix this problem?
I'm not familiar with quilting machines, but I have heard conversations about problems occurring when the fabric sandwich is stretched too tight so it is "trampolining" when it stitches. Also, the needle may need changing. Could be that the thread is too heavy for the needle being used.
JM humble guess!
Sep 25, 2016 | Sewing Machines
Singer 27
What kind of thread are you using. The most often problem today is that the thread is too thick for the size of needle. Try using a Metallica size 90 or a top stitching needle size 90
if the thread is a cotton type or a quilting thread it is often to thick to travel easily through the eye of a needle quickly to form a good stitch.
Aug 03, 2014 | Singer Sewing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
How do i adjust the loose thread on top? Using the 3 thread stitch the top loop is loose and bulging over edge instead of smooth with rest of stitches. Setting is set to recommended setting but is still...
I always adjust my overlocker stitch in several ways. I start test serging with the blade set right out to the right so that it "fills" the stitching. I'll set all the thread dials to the middle setting, ie. 5. Then I test serge, and check the stitch formation. If the needle is looping underneath, then I'll tighten it "A LITTLE". If the looper threads are lying off the cut edge of the fabric, then I'll dial both the top and bottom looper numbers up a little to make those threads tighter.
Each fabric behaves differently depending on its "hand" so the right stitch settings do vary, ie. organza is different to heavy weight cotton or denim. So if my inital setting is then "bunching" up the fabric within the stitching, I will then lower the numbers for the top and bottom looper to release the thread some. And if the fabric is very soft and light and still bunches up, then I will move the blade over to the left some, cutting a narrower edge within the overlocking so the threads lie better.
So revist the settings, check that the cones are flowing freely, thread is into the tension devices fully, then retest the stitching. If it is the top looper only that is looping off the edge, and not the bottom as well, and they are both set to the same number, then I'd be a bit suss about the tension dial.
Feb 28, 2011 | Singer 14SH654
Just bought a darning foot to use in quilting but don't know how to use it
You didn't specify your machine brand or model which may make a difference in setting it up.
Using the machine with it in a cabinet or flat extension plate is necessary to allow easy movement and keep the fabric flat. Make sure that you have enough layers of fabric to give stability to the stitch.
With the needle bar in its highest position and the presser bar up, install the foot on the machine. Lower the feed dogs (if your machine has the feature), set the pattern for straight stitch and LOWER the presser foot. Hold the upper thread with your left hand and make one rotation of the handwheel with your right hand. Pull the top thread and the bobbin thread will come up with it. As you stitch, move the fabric in an even, fluid motion. This will take a little practice, but it will get easier with time. Make up some "sandwiches" to practice with. A sandwich is two pieces of cotton fabric with batting in between, usually six to ten inches square.
Your upper tension may need to be adjusted a number or two up or down. Experiment!
Jun 27, 2009 | Husqvarna Sewing Machines
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Jan 28, 2009 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
158 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
