Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag jet clean
My maytag  jet clean is not cleaning the dishes on the top rack. I've removed and cleaned the rotating top arm, as well as the bottom ones. I am at a loss as to what else could be wrong. Does anyone have some ideas for me to try.
  • 93 Answers
If the arm has a crack or is broke pressure will not turn it properly. Also check the rubber boot that seal the wash arm on the rear supply tube. If the rear supply tube holes are not sealing from inside with the rubber flap seal that will effect it also.
Posted on Jul 24, 2008
The dishes wont come clean on top rack? the bottom rack is clean..we tried cleaning filter and making sure the wash arm wasnt hitting anything..we tried different wash settings..please help ...
Check that the top rotating arm jets are not block. These often get blocked by pieces of food or other solid particles, this is the normal problem.
Feb 02, 2011 | Whirlpool DU1055XTS Built-in Dishwasher
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
SHU43C06UC dishwasher cleans dishes on bottom rack but leaves dishes on top rack dirty
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Nov 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes on the top rack not cleaning properly
Had similar problem with our Maytag dishwasher--we removed all spray and screen components to the inner case, cleaned the intake screen below the lower spray arm, repaired a split upper spray arm, and inspected everything for cracks or other distortion. All of this helped some, but finally improved things by changing from liquid detergent to a "packet" type. Our water is somewhat hard and builds deposits on the screen at the bottom. Run a no-dish cycle with a cup of white vinegar in the bottom.
Aug 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Kenmore Quiet3 not cleaning top rack, now stopped cleaning all
The problem is likely that the cutter/chopper filter is plugged. This reduces or eliminates water flow to the cleaning arms.
Solution:
Remove dish baskets
Remove bottom arm - Rotate the centre post until arm is free to be lifted out.
Remove conduit to top arm(s) - Remove 2 screws, one at top and one at back. Rotate whole conduit 45 deg right and lift off of centre post.
Remove bottom plastic assembly. - Remove 4 screws and lift off.
Remove cutter cap. - Remove 1 screw at front left. Lift off plastic cap. Remove cutter filter. It is on a spring loaded pin. Pull cutter blade foreword and lift filter disc straight up. Clean filter disc thoroughly
Reassemble!
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
No-spin
the spinning of the arms is created by the force of the water shooting out of the holes. your top arm may have debris build up in it that prevents proper water flow. u can also remove the arm and see it there is build up on the contact point were it rotates. clean it if its dirty. "dishwasher magic" is good for cleaning mineral build up in your system. also, make sure your not putting dishes on the top rack that are too tall and prevent the blade from rotating
Dec 01, 2008 | Maytag MDB9600A Jetclean II Built-in...
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
177 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
